EA to EJ LSD
EA to EJ LSD
G'day,
seems my chance of getting a 3.9 CLSD from an L series
are pretty low.
So I'm wondering if I can get one from an EJ?
What's involved?
What am I looking for in a Diff for it to be easiest?
What is the easiest way to do it?
What else, if anything needs to be swapped?
Cheers all
are pretty low.
What's involved?
Cheers all
your talking rear diff right??
well my guess is they would be the same (almost) as the vicous ones so you need to work out fitting one of them to the ea's, i seem to remember a few post about it on here
the internals are the only thing that should be differnt IF you can get one!!
if im needed for anything spike.pickstock.racing@hotmail.com and ill try and get back to you.
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
G'day,
Yeah it will fit in your L series no problems, the housing is the same as Liberty & L series. But the flange can be different size/shape and a press/gear puller is required to pull it off.
as alpine raven has shown this is not my area of expertise
but i would imagine the splines are the same as the viscous diff in which are different from the Ls
GETDIRTYCLOTHING
GETDIRTYCLOTHING
- twilightprotege
- Outback bloke
- Outback bloke
- Outback bloke
yes and yes... MAKE sure the stubs are in the diff, they can be pulled out and both side (left and right) are different length.
If there is no stubs then you have a very hard chance to find stubs for the LSD - so be aware.
I'm pretty sure its the same as L series - Liberty splines.. Because I had one L Series cup from the diff a while back and fitted on gen 1 liberty.
edit: if you really need to know how many splines there are - i have an LSD in the garage with stubs and I can count it if you like..
