putting a locker in an of foz
i am wanting to put a locker in my rear diff, can it be done? how hard will it be? any help would be great.
Thanks Mike.
Thanks Mike.
nuthin beats a subbi
Previous rides: 1998 rx liberty sedan, 2007 mitsu 380 and now a 2005 foz, lifted with bigger and black wheels ( Got rolled
) and now a 100 series land cruiser.
What car? I'm guessing you're talking about the commonwhore?
can be done, but i dont think theres any switchable options. Youd have to either weld it, or you can get a locked diff centre, subaru do them.
nah, in my foz paul. i am just going to weld the commy one.RSR 555 wrote:What car? I'm guessing you're talking about the commonwhore?
Cheers Mike.
oh.. sorry mate.. I didn't read the title properly
Umm.. Like Alex has mentioned welding or find a RX Turbo Leone diff.
yeh, i dont know what i am doing though to weld it, how much do you recon i could pick one up for?? what i really want to do is make it rear wheel drive and then make it so the front wheels will engage when i put it in 4wd. like a propper transfer case. but that is to hard so yeh. haha.
Cheers Mike.
Cheers Mike.
i amn more than happy to do the commy one, because i dont really care if i stuff that up, but as for my foz, i really dont want to stuff that one up.
Cheers Mike.
Cheers Mike.
if you weld it you know youre gunna be squeeling around corners in carparks n shit, and also wear out tyres twice as quickly.
Not sure if its an option for ya, but you can remove a rear cv shaft to prevent this. Not sure if the AWD system will like it tho.
- TOONGA
just a few topics on the subject
search.php?searchid=448377
including yours
it can be done but it isn't cheap
including yours
swap it out for a nissan 190 i think was the diff code
and then you can get lockers for them
pickstock racing fabrication
pickstock racing photography
GETDIRTYCLOTHING
GETDIRTYCLOTHING
what is the nissan 190?
- discopotato03
A H190 is a Nissan live axle type differential . I think they were some sort of metricated copy of an early pomy diff , silly things like carrier bearing adjustment via shims on the hemisphere side of the hemisphere .
Datsun 620's and 720's had a version of the H190 and I presume the Detroit locker hemisphere was intended for them . I had an ex rally one in the bum of my old Bluebird and I wouldn't use one in a road car again by choice .
A .
A .
hmmm
yeah the model up from the R180 cause the 180 is what i got in the l
and the 200 is wrx or such
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Interesting..GOD wrote:Never heard of a 190, but NIssan has used R180 and R200 diffs in the front of IFS Navaras and Pathies, and there are/were switchable lockers available for these.
Dane.
this started out about me putting an lsd in my l seires on a rally, well there happend to be a more modern wrx.
the 180 fits in a l seires and the next one up, 190 or 200 fits in the wrx, probably the same in a foz dunno, and then you can still get limited slip diffs and lockers for both of the diffs i presume
GETDIRTYCLOTHING
GETDIRTYCLOTHING
Your L series has a r160 rear diff and so do all other Subaru's, except for later STI's, which have r180 rear diffsspike wrote:hmmm
- discopotato03
ok thanks for clearing that up but he seemed pretty sure that datsun/nissan diff centers are the same size and interchangeable, with a diff lockSuparoo wrote:Your L series has a r160 rear diff and so do all other Subaru's, except for later STI's, which have r180 rear diffs
GETDIRTYCLOTHING
GETDIRTYCLOTHING
I am not sure if this would work and I dont have the funds or the time to do it.
But if you used a r180 sti diff housing (starting to get more common) and then put a navara r180 diff with a lokka centre (just released early this year) then you would have a good strong auto locking diff and upgraded sit rear shafts to go with it.
