remove engine from OBW.
0) remove bonnet
1) release fuel pressure
a) disconnect fuel pump. Connector under rear back seat.
b) start engine and run till it stops
2) disconnet fuel hoses to engine
3) remove coolant
4) remove radiator
5) disconnect heater hoses
6) disconnect brake booster vacuum hose
7) remove air filter assemblies
9) remove battery
10) disconnect alternator and remove
11) disconnect electrical connectors
12) detach air compressor
13) detach accelerator and cruise control cable
14) remove power steering pump from bracket
15)Remove pipe with bracket.
16) Remove bolts which install power steering
pump bracket.
17)Remove bolts to header pipes.
b) remove bracket holding header pipes rear of engine
c) unbolt from center exhaust pipe.
18)Remove nuts which hold lower side of transmission
to engine.
19)Remove nuts which install front cushion rubber
onto front crossmember.
20)Remove pitching stopper.
21)jack under transmission
22)remove bolts which hold transmission to engine
23)remove starter
24)lift engine
writing a list like this sure makes it look like a lot of work.
Anyway heres the main reason posting this topic.
The Subaru manual has in the remove procedure to "collect the refrigerant"
in removal of AC. Now I been looking at it for a bit, and I reckon the compressor could simply be detached and placed to where the battery
sits, am I right or missing something ?
The manual also seems to stress support the transmission with a jack. I mean at all times? there is a cross bar to support the transmission isn't there? I mean is it not sufficient in the OBW ? the reason I ask is that I
will need to push the vehicle minus the engine to another location for a while......
oh if you have corrections or added tips,advice to the list above please yell out.
Is it a good idea to get new exhaust bolts ?
exhaust bolts aren't Subaru specific are they? should be able to get some
from the exhaust shop cheaper and no need to order huh?
