Gen 1 EJ22 'Little End' bearings...
Looking for a little help here...
I have a 6/91 Gen 1 EJ22 I am rebuilding.
After disassembly & inspection the 'little end' (Gudgeon pin to con rod) bearings on 2 of the con rods are completely stuffed.
There are no aftermarket ones available that I can find.
Genuine Subaru one comes with a new con rod.
But the Gen 2 (6/94+) EJ22 lists the 'Little end' bearings as a part.
My question is the con rods the same between the Gen1 & Gen2 EJ22? Do they share the 'Little end' bearings??
Thanks in advance - Justin
http://www.subiparts.com.au
0438 887 746
0438 887 746
No one knows???
0438 887 746
0438 887 746
First I must say a HUGE thanks to Andy (FROG) for his help on finding a part number for the conrod bushes from the later model EJ22.
The answer is Yes they fit.
Apparently ALL liberty (EJ22,EJ20,EJ25) use the same conrod bush/bearing
0438 887 746
0438 887 746
- FROG
Good to know
didi you just buy one and try it or......?
I bought the set of 4 & hoped they fitted in...
0438 887 746
0438 887 746
