inlet gasket
esray71
inlet gasket
Post by esray71 » Wed Jul 16, 2008 6:05 pm
anyone had experience with replacing gaskets? should i use sealant when i put on new inlet gaskets or do they not require sealant?
Post by Gannon » Wed Jul 16, 2008 6:16 pm
It says in the repair manuals "gasket sealant not required"
I didnt use any on mine (ACL gasket kit) and i havent had any problems in the 16 months since i rebuilt it
esray71
Post by esray71 » Wed Jul 16, 2008 6:36 pm
well i suppose the gasket should compact and seal well enough if the bolts and done up tight enough. I'd hate to replace them and get air sucking in.
Post by El_Freddo » Wed Jul 16, 2008 10:09 pm
I've always used genuine inlet gaskets from subaru and never had a problem. I do this because of advice from one of dad's old mechanic mates. He's had problems with aftermarket gaskets failing between the inlet port and the coolant passage.
I usually use a little bit of sealant and scrape the surfaces clean before fitting it all back together...
