inlet gasket
inlet gasket
anyone had experience with replacing gaskets? should i use sealant when i put on new inlet gaskets or do they not require sealant?
It says in the repair manuals "gasket sealant not required"
I didnt use any on mine (ACL gasket kit) and i havent had any problems in the 16 months since i rebuilt it
I've always used genuine inlet gaskets from subaru and never had a problem. I do this because of advice from one of dad's old mechanic mates. He's had problems with aftermarket gaskets failing between the inlet port and the coolant passage.
I usually use a little bit of sealant and scrape the surfaces clean before fitting it all back together...
