Cooked EJ22 - Options?
Post by AndrewT » Fri Nov 26, 2010 4:14 pm
heh, the simple fact that it's got "Legacy" written on the car means it's a private import so comparing it to locally sold cars is going to add to confusion.
Yeah looks like your best bet will be to find a replacement EJ18 short motor, then it will be a fairly simple weekend job to swap in and use all the existing electronics to run it.
If you want to change to a multipoint injected EJ system like all the Aussie Subaru's have then it's a fairly involved conversion from a wiring perspective. Not too complex for someone in the know with that side of things, but complex for your average home mechanic.
Jock
Post by Jock » Fri Nov 26, 2010 5:08 pm
AlpineRaven wrote:EJ18!?
Na I originally thought the mess in under the dash was something to do with an immobiliser ;)
Think I may just stick with an EJ18 save stuffing around
The same wreckers just happened to have an EJ18 out of a 94 Impreza, done 120,000. Same deal $1100
From what people are saying that seems a bit steep, so I might have a look in a few other places
Like here:
http://www.brisbanemotorimports.com.au/ ... ubaru/ej18
Half the price ;)
Post by TOONGA » Fri Nov 26, 2010 5:43 pm
when you add another 1300 dollars to the 1100 dollar price tag you can buy a recon short block.
$550 is a way better price but if you hunt around a bit more you could do even better
Jock
Post by Jock » Fri Nov 26, 2010 5:47 pm
TOONGA wrote:when you add another 1300 dollars to the 1100 dollar price tag you can buy a recon short block.
No worries
Any hints on places to look?
d_generate
Post by d_generate » Fri Nov 26, 2010 6:05 pm
Most people throw them away, a mate of mine sold one with 70k on it for $90 with wiring & computer, you really need to to join something like RSLC or some Impreza forums, possibly REXNET and put a wanted add up, heaps of people have done conversions and have the old motors laying in their sheds, you may also be able to use a 2L block, ask Al on RSLC, he knows pretty much everything about what will fit what & may have a spare motor laying around or be able to get you one cheap.
Here is Al's web site, call or email explaining the problem & hopefully he'll be able to help you out.
http://amauto.com.au/
Jock
Post by Jock » Fri Nov 26, 2010 7:42 pm
d_generate wrote:Most people throw them away, a mate of mine sold one with 70k on it for $90 with wiring & computer, you really need to to join something like RSLC or some Impreza forums, possibly REXNET and put a wanted add up, heaps of people have done conversions and have the old motors laying in their sheds, you may also be able to use a 2L block, ask Al on RSLC, he knows pretty much everything about what will fit what & may have a spare motor laying around or be able to get you one cheap.
Thanks for that mate
Think I joined the RSLC forum, I'll stick an ad up
If you have any other mates selling them with low ks sing out :p haha
Jock
Post by Jock » Fri Nov 26, 2010 7:52 pm
Post by RSR 555 » Sat Nov 27, 2010 12:58 am
I have one from an Impreza (about a 97 model) not sure how many kms? was going to fit it into Gleno's L until we stripped the Liberty. You can have it for $300 but I'm not sure what freight from WA will be to you? maybe you can make some calls?
Paul
Jock
Post by Jock » Tue Dec 14, 2010 5:23 pm
Well it's back on the road.
Many thanks to all of you for your help
If anyone wants an EJ18 with slightly scored bores and two warped heads minus a few parts. Sing out and I'll gladly sling it your way
Post by El_Freddo » Tue Dec 14, 2010 5:26 pm
So did you end up with a replacement EJ18 or EJ22?
Jock
Post by Jock » Tue Dec 14, 2010 6:30 pm
I got hold of an EJ18 from an Impreza and swapped the camshaft, distributor and front timing pulley
Saved stuffing about to much, mum needed her car back
