ea82 gear box onto ea81 engine
heath
Post by heath » Fri May 02, 2008 12:26 pm
does anyone no how hard this is to do. are the bell housing bolts line up or do i have to make a boss kit
dfoyl
Post by dfoyl » Fri May 02, 2008 1:03 pm
Search and you will find...this topic has been covered a few times :)
The bell housing pattern is the same, you have to fiddle with the 4wd selector mount length as the L series uses a different mechanism. EA82 box is different length than EA81 so you need a custom-length tailshaft or you can use the L series 2-piece unit.
Dean.
