EA82T fuel filter
EA82T fuel filter
Car is running like crap so just going along ruling problems out, I am going to change the fuel filter as I never have yet in this car.
At the moment it does not have a standard suby filter, looks like a commodore one (out of a VL?). Anyone ever heard of this? Think of a reason for it? Cheaper? More flow?
Also anyone know if the EA82 and EA82T filters are the same?
I just got a universal EFI (make sure its EFI) fuel filter from Super Cheap.
Smells probably a bit stronger than usual, but not sour really.steptoe wrote:Ya could be right. Modern day ULP does not seem to have a shelf life. A mate pulled a yammy 80 carby apart last week. As I arrived all i could smell was STALE petrol I thought was years old, but it had only been in since xmas.
So, does ya fuel have a really bad smell to it, more than usual?
So what’s what the remedy for stale fuel? Just top the rest of the tank up with fresh fuel? Add some octane booster?
use it or remove it (keep, just in case its not the cause) and try fresh. The first 20 litres I used in my new Brumby engine [ea81 carb] rebuild pinged and carried on, didn't like to idle consistently. This cats piss had been around 18 months and six months and mixed. Ran it real low and filled it afresh and by the first 100km or so it ran fine and happy. Dunno why ??? just fresh fuel ??
Very lumpy at idle and running. All temps, all speeds. Worse under load, revs easily up its range when not under load although still rough. Very low on power when driving, struggles to reverse up driveway. Surges when cruising along and not under much load, slight surges at idle as well.steptoe wrote:Hows about using some more technical and descriptive terms ~ crap is so broad a term to use in here for dagnosis.
start up cold, start up hot, all temps, all loads, all speeds, or particular revs/load/speed boosting?? gear
I reckon one cylinder is not firing and the injectors are my next suspect.
INJECTORS!!
I had a spare set laying around so i went and got them serviced/cleaned/flowed and then swapped them into my car this weekend.
Idles heaps smoother, low speed driving around town is smoother too. But the biggest difference i discovered, it pulls all the way to 6k with no hesitation at all.
(i had a stumble at 3k and it wouldnt pull past 5 before i replaced them)
Also, if you think your fuel pressure regulator is not working, get one for an N13 Pulsar or a JD/JE Camira (they are the same BOSCH part no.) It is practically the same as the Subaru one, but can be found at your local parts supplier.
- discopotato03
i paid $80 from injectacarb.com
I wouldnt bother with a fuel pressure regulator from the wreckers, its probably gonna be in the same condition as the one in the l series (rubber diaphragm lost its rubber-ness)
I really did not want to pull the injectors out, so I went back and double checked all the simple stuff again. But this time I actually tested the spark leads, one was gone and possibly another as well. It was just the leads:oops: .steptoe wrote:Thomas, waddijado to fix your beast ?
Fiddled with the idle, checked the timing, changed some fluids, and shes running sweet now.
