Fortnightly Clutch Adjustment.
SuBaRiNo
Post by SuBaRiNo » Mon Dec 25, 2006 9:16 pm
There are many many reason why im not running the lib box.... and im far from wanting to have the car off the road for that long and spending that sort of money at this stage. Maybe later down the track.
Yeah im begining to think it is the clutch physcailly fallen apart although after adjusting it works fine... weird.. I could not decifer anything else u said... maybe it is in code or u had too many crownies.
Thanks OS
Dave
Brumby Boy
Post by Brumby Boy » Mon Dec 25, 2006 9:30 pm
why does everyone pull the engine to do the clutch on here? i have been brought up to pull the box out, i find it alot easier, well at least with a hoist. though when we did the manual convert in my cousins commo on the floor it wasnt too bad.
RIP 1992 Brumby
Oversteer
Post by Oversteer » Mon Dec 25, 2006 9:33 pm
errm Coronas this Christmas !
Who made the clutch ? Autoclutch ?
Can you fit a lib flywheel inside the EA bellhousing ?
La Cerveza Mas Fina ;)
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
SuBaRiNo
Post by SuBaRiNo » Mon Dec 25, 2006 10:18 pm
Not sure on either OS. I don't belive so with the Lib clutch fitting.
Brumby Boy... if the car had the standard box and engine then i wouldn't pull the engine... actually if it was the stock motor it would only take about an hour to pull the motor and put it back in anyhows.
I have an EJ22 in an ea81 engine bay... gives me about 10mm at best clearance on either side and the front.... i can't even move the box back far enough to slide it off the input shaft. Thats why i remove the motor... turns out much much easier.
Dave
Dave
mattims
Post by mattims » Tue Dec 26, 2006 5:22 pm
jaffa took the clutch i had away .. so you might be able to get it of him .. cause he hasn't actually paid for it yet.
if your still looking for a new one.
SuBaRiNo
Post by SuBaRiNo » Tue Dec 26, 2006 5:43 pm
DAMN IT!!!
My fault... thanks Mattims.
Dave
Brumby Boy
Post by Brumby Boy » Tue Dec 26, 2006 7:06 pm
SuBaRiNo wrote:Brumby Boy... if the car had the standard box and engine then i wouldn't pull the engine... actually if it was the stock motor it would only take about an hour to pull the motor and put it back in anyhows.
Dave
Dave
oh ok i mainly work with newer soobs and with a hoist. i suppose ill learn all the tricks of gear box fitting/removal when i fit my ej22 and 5 speed
RIP 1992 Brumby
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Dec 28, 2006 2:55 pm
BY what your saying it sounds very much like its the release fork is cracking and spreading apart at the pivot
The long road ahead
tim_81coupe
Post by tim_81coupe » Thu Dec 28, 2006 7:33 pm
Suby Wan, you are on the money. Dave will no doubt post pics, so I'll leave it to him to explain.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Post by Subafury » Thu Dec 28, 2006 8:36 pm
so tim can hatchie come out and play?
tim_81coupe
Post by tim_81coupe » Thu Dec 28, 2006 11:33 pm
Daveeeeeeeeeee......... hurry up and post! They're asking me all sorts of questions!!!
Hatchie can drive all the way out of my driveway and up the street, possibly further than that as Dave didn't walk back here afterwards.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
SuBaRiNo
Post by SuBaRiNo » Fri Dec 29, 2006 1:53 am
Yeah hatchie is all good now... just need time to tindy up the engine bay a bit and add some of the bash plates and splash guards back on.
Yes it was the fork as i began to expect although it was much more stuffed than i had imagines... i will post pics when i have time.
Also i found that one of my gear box mounts is actually not functioning at all so i will have to give that some attention also.
Dave
waggaclint
Post by waggaclint » Fri Dec 29, 2006 9:09 am
didnt ya replace the fork when we did ya motor dave?
2011 Forester X
SuBaRiNo
Post by SuBaRiNo » Fri Dec 29, 2006 10:41 am
Yes i did.... but it's not exactly a part that is meant to wear out... or a part that can be purchased easily new. I also looked into getting the old fork strengthened before i put it in but it could not be welded for some reason.
Shit happens.
Dave
SuBaRiNo
Post by SuBaRiNo » Fri Dec 29, 2006 10:48 am
waggaclint
Post by waggaclint » Fri Dec 29, 2006 11:07 am
fukn mate not nice its all the power of that new engine maybe these clutches you guys are using are too HEAVY has any of the other guys had the same problem? you might have get one custom made if it happens again mate....or dont drive as hard hey lol
2011 Forester X
SuBaRiNo
Post by SuBaRiNo » Fri Dec 29, 2006 11:15 am
I have seen it happen on one other car running the same clutch set up.... if it goes through another one i will have to re think my clutch/box options.
In saying that though i have seen one crack from running the stock clutch.
Dave
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Dec 29, 2006 6:34 pm
I have seen a few of the release forks crack in similar fashion even with std clutches infront of them. It may be just a result of fatigue accelerated by a heavy clutch.
The long road ahead
Post by AndrewT » Fri Jan 05, 2007 12:47 pm
Dave if its any help, that one I gave you which you are now running was taken from an RX Turbo! Mabey its stronger!!
hehehe (not)
tim_81coupe
Post by tim_81coupe » Fri Jan 05, 2007 7:21 pm
Well it looked identical... still might have been a slight difference though.
We greased up the cup in it where the pivot ball sits, this might help it last a bit longer!
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
