Bad Flat Spot
- Brumby Boy
Bad Flat Spot
Ok over the last few weeks my brumby has been developing a very bad flat spot. it seems to be between 60 to 80km/h regardless of throttle position except below 1/4 throttle. if i accelerate very gently it dosnt seem to be as bad. has gotten worse since i WAS using ethanole but have now gone back to regular unleaded approx 4 tanks and it is still getting worse. i think it may be the ethanol has eaten the rubbers in the carb and or the fuel filters all need replacing. wat do you all think?
Turtle
Turtle
RIP 1992 Brumby
RIP 1992 Brumby
- Suby Wan Kenobi
The ehtanol may have dislodged some crap hiding in the carb and it is now partially blocking a jet now. If you dont remember how old your fuel filter is you should consider replacing it anyway. Spray some carb cleaner down the throat to clean it up other wise it pull the top off the carb and see whats going on.
The long road ahead
The long road ahead
- Brumby Boy
sweet thanks guys
i havnt changed it since ive had the car so god only knows how old the fuel filter.
im not gunna bother fixing the carb as my ej should be done early next year ill just live with it i think.
Thanks again
Thanks again
RIP 1992 Brumby
RIP 1992 Brumby
- Brumby Boy
Dunno havent looked
ill have to do it when i have light tomorrow
RIP 1992 Brumby
RIP 1992 Brumby
- BaronVonChickenPants
