H6 'VVT' fit SVX EG33?
a mates father has asked me if i know if this has been done/will work. (hey, i only drive a Brumby - I DO NOT KNOW) but someone in here may know , like Steve and Daniel
- brumbyrunner
- BaronVonChickenPants
In theory if you can get hold of a Gen 4 EZ30 it should fit as it's a physically smaller engine, but I have no idea if it will directly bolt up to anything, to be honest I doubt it.
But all you're really going to gain is an engine with the same power and slightly less weight and a major wiring headache.
Jordan.
Jordan.
- Ben
I'm with Jordan, but think that it all would directly bolt up. Also, as Jordan said you would gain nothing in the conversion.
That said, if the motive is to find a cheaper than EG33 replacement for a dead motor I think the install, unless completeable by your mates father in entirety would be more expensive than getting a full rebuild on the dead engine.
- FROG
svx
http://www.subaru-svx.net/forum/forumdisplay.php?f=4
these guys would be able to help you out id imagine
It was an idea that someone entered into his head. I thought I'd ask. I thought someone may have said EG33 is belts (at the front?) and EZ30 is chain drive (at the rear of engine??) Is it electronic ? not oil driven like sister (SPIT) company nissan?
engine is sweet
also sounded lke one of those hair brained ideas like an EG33 into a Brumby - and that sounded like a piece of cake for Daniel
engine is sweet
- brumbyrunner
EG33 is timing belt. EZ30 is timing chain. Both at the front.steptoe wrote:It was an idea that someone entered into his head. I thought I'd ask. I thought someone may have said EG33 is belts (at the front?) and EZ30 is chain drive (at the rear of engine??) Is it electronic ? not oil driven like sister (SPIT) company nissan?
engine is sweet
Did you just want to put an EZ30 into an SVX (unlike my original interpretation)?
Should be very do-able with a huge improvement in centre-of-balance.
Wouldnt the bolt on to the transmission be different?
