EJ+AWD into MY. ratios and sway bar questions
should be in conversion section I know.
Question #384 on EJ's and MY
I've been researching old posts re MYEJAWD conversions
find front sway bar off normal Brumby/wagon cannot stay if not raised
TRUE/FALSE
alternatve mentioned was auto 4wd bar (was that L or MY)
EJ's didn't come out in 3.7 ratio
TRUE/FALSE
BVC tells me his single ratio AWD lib box is 3.7 , i think.
TRUE/FALSE
TRUE/FALSE
Ej My
The MY swaybar won't fit as it fouls on the EJ Gearbox crossmember, I am not sure about an auto 4wd one. L series can be adapted particularly if you convert to L arms at the same time. Early Lib dual range were 3.9 went to 3.7 with Gen 2 so 1994 on. Most Impreza were 3.9.
- vincentvega
Gen 2 Liberty are 3.7 dual range boxes (and same goes for single range)
1st Gen Liberty were 3.9 both single & dual range.
- BaronVonChickenPants
You didn't miss it, I never thought to list it. I intentionally bought an automatic car for the conversion because I did not intend to lift it, and the auto has a bigger transmission tunnel and sway bar to accomodate the EJ gear.
If someone wants it make me an offer.
Jordan.
Jordan.
