MY04 Liberty RPM hunting at idle
555Ron
Post by 555Ron » Wed Jun 25, 2014 5:09 pm
Hi, the RPM on my Subaru Liberty drops off at idle - but only when the air conditioner is on. It idles perfectly if you turn the A/C off. But with it on, when the clutch engages on the compressor the engine begins to die. It seems like the clutch releases at very low RPM and it the revs pick back up. The air conditioning works well during driving and and there is no indication that the compressor is on its way out. Any ideas? I cleaned the MAF sensor but no luck.
- Rhys
91 Brumby
Post by RSR 555 » Thu Jun 26, 2014 4:43 am
When was the last time it had a can of Subaru Upper Engine Cleaner in it?
555Ron
Post by 555Ron » Sun Jun 29, 2014 3:35 pm
Good question. I'll grab a can and give it a go. It's not critical which vacuum hose it goes into, is it?
- Rhys
91 Brumby
Post by El_Freddo » Sun Jul 06, 2014 10:05 pm
555Ron wrote:Good question. I'll grab a can and give it a go. It's not critical which vacuum hose it goes into, is it?
Not really, there's a good one above the throttle body ;)
As for your AC, I'd check the idle up circuit to make sure it's working.
555Ron
Post by 555Ron » Fri Jul 11, 2014 4:56 pm
Cheers Bennie. It probably is something electrical like that. I think I'll just book it in and pay the money to have it fixed.
- Rhys
91 Brumby
