FB16 with a low mount turbo and direct injection
A lack of power steering pump suggests an electronic power steering pump
Definitely chain driven but to me the cats are after the turbo.. from these pics you can't see the header pipes to the turbodiscopotato03 wrote:Looks like four cam angle sensors and a cast front case almost certainly means chains instead of belts .
The lower front mount turbo has been done before but I don't know about cats before the turbocharger .
A .
That's what always had me puzzled with cars like AWD skyline's and the AWD commodore's?Gannon wrote:the engine is too far back to allow front driveshafts.
SORRY Upon reflection, it might just be one of the shafts passing through the diff with the diff externally mounted...El_Freddo wrote:I know the AWD skylines had the front diff in the engine sump! I kid you not!!
A wagon variant of the Nissan Skyline.. some come with the full GTR spec running gear.. NOICE !!nncoolg wrote:what is an exiga exactly? it it subaru, or is it 'borrowed'
I agree, highly unlikely the cat before the turbo. Looks like exhaust manifold reversed to exit stage left rather than right as per the unturbo'd XV. Compare with <http://drive2.subaru.com/Win11/itsWhatMakes.htm>RSR 555 wrote:Definitely chain driven but to me the cats are after the turbo.. from these pics you can't see the header pipes to the turbo
