VDC on H6
wombataaron
VDC on H6
Post by wombataaron » Thu Oct 27, 2011 6:34 pm
I've never used my car on a beach or anywhere where traction is not great, has anyone with the VDC system found it hinders your ability wth it always cutting in and cutting your power?
MY00 Outback
3" lift
Bullbar
Sump Guard
Yokohama Geolander AT-S
skipalami
Post by skipalami » Thu Oct 27, 2011 7:11 pm
Just switch it off while you are on the beach.
Post by Gannon » Thu Oct 27, 2011 7:34 pm
I dont know that it cuts the power.
It only controls the ABS unit to direct braking to individual wheels to keep the car travelling in the direction you point the steering wheel. It also varies the amount of lock up of the VTD centre diff.
Post by RSR 555 » Fri Oct 28, 2011 7:18 am
Are you getting torque bind when turning sharply? or any shutter from the brake pedal when pressing firmer than normal on them?
wombataaron
Post by wombataaron » Fri Oct 28, 2011 10:08 am
Theres no problem with it was just curious if anyone has used it , say on the beach and found it to be more annoying then helpful?
It cannot be turned off either.
MY00 Outback
3" lift
Bullbar
Sump Guard
wombataaron
Post by wombataaron » Fri Oct 28, 2011 10:12 am
Actually when i do turn sharply, normally in reverse i find sometimes to wheel kinda jerks loose then tight again, kinda strange, also kinda off topic does anyone find if they park their car on a steep driveway then start the car and try and put it in gear there is massive resistance and it often clunks with force into gear? I rung subaru and they said its normal its just the gearbox when its cold?
MY00 Outback
3" lift
Bullbar
Sump Guard
H-top
Post by H-top » Fri Oct 28, 2011 10:27 am
Mercedes Benz 5 Speed Auto 72226 gearbox's have the same drama, its no biggy.
H-Top
rolling in
H-top
Post by H-top » Fri Oct 28, 2011 10:29 am
wombataaron wrote:also kinda off topic does anyone find if they park their car on a steep driveway then start the car and try and put it in gear there is massive resistance and it often clunks with force into gear? I rung subaru and they said its normal its just the gearbox when its cold?
H-Top
rolling in
pezimm
Post by pezimm » Fri Oct 28, 2011 5:24 pm
RSR 555 wrote:Are you getting torque bind when turning sharply? or any shutter from the brake pedal when pressing firmer than normal on them?
I haven't got VDC, but I certainly get the pedal shutter when going down a dune and pressing on the brakes...
I believe it's just the ABS system kicking in due to wheel lockup, isn't it?
Pedro
Post by Gannon » Fri Oct 28, 2011 7:48 pm
Yeah just the ABS.
If the car you are referring to is the 07 XT Foz in your sig, are you sure it doesn't have VDC/ESC?
Post by RSR 555 » Sat Oct 29, 2011 3:40 pm
wombataaron wrote:Actually when i do turn sharply, normally in reverse i find sometimes to wheel kinda jerks loose then tight again, kinda strange, also kinda off topic does anyone find if they park their car on a steep driveway then start the car and try and put it in gear there is massive resistance and it often clunks with force into gear? I rung subaru and they said its normal its just the gearbox when its cold?
Doesn't sound right to me but without seeing it firsthand it's a bit hard to say. I would look at making sure your fluids are upto date with their changes.
pezimm wrote:I haven't got VDC, but I certainly get the pedal shutter when going down a dune and pressing on the brakes...
Pedro
ABS and sand does not go well together :( I find it better sometimes to remove your ABS fuse when your on the soft stuff.
What I have found in some of the later models is the ABS ring on the front wheel bearing/s giving troubles/faulty readings to the central control system. This is causing weird brake pedel feelings (like a 1/2 the feeling you'd get when your ABS is fully locked in emergency situation) and trouble codes on the system. When this happens the centre diff plays havoc.
