ignition module
blackbrumby
ignition module
Post by blackbrumby » Tue Jul 01, 2008 6:02 pm
Can anyone help my ignition module has stopped working were can i replace it from its out of a ea82t
Post by Gannon » Tue Jul 01, 2008 6:18 pm
Your talking about the power transistor mounted on the coil bracket?
One off a MPFI touring wagon, or maybe scout the local wrecking yard for 80's Nissans, one off them will do the trick, or you could pull it apart and get the number off it and buy a transistor from Dick Smith Electrical or Jaycar and fix it that way.
Post by Gannon » Fri Jul 04, 2008 5:49 pm
If you are referring to the module inside the distributor, ignore my above post.
What you have in there is a Magnetic Reluctor & Hall Effect Sensor that gives a pulse twice every revolution to drive the ignition coil.
I think the module from any L series carby engine will do the trick.
Post by steptoe » Sun Jul 06, 2008 11:08 am
I think any Hitachi dizzy from same era with the two pin module will do it , Hondas and nissans spares places should have a listing too
