Libby's Build Up (*pics*)
Post by El_Freddo » Wed Apr 07, 2010 9:17 pm
G'day Owen.
I'm still keen to come down tomorrow (thursday) to help out. I've sent you a few messages and tried to call your mobile but it's apparently turned off.
If I don't hear from you by the time I would normally head off to work that's where I'll be headed for the day... My mobile number is zero four two one one eight four zero three one. I'll need your address for the GPS gadget to direct me your way ;)
Hoping to hear from you, and that you're a night owl...
ScubyRoo
Post by ScubyRoo » Fri Apr 09, 2010 12:28 am
Captain Obvious wrote:must be time for more pics!!
All in due time... but for now:
More pics to come tomorrow :)
Owen.
banger
Post by banger » Fri Apr 09, 2010 5:11 am
if the top one has a honey comb in it than it is a cat the bottom is definitely a hot dog if you have a straight through muffler on the back it will drone with the hot dog you really need to run 2 of them you will thank your ears for it they are only cheap you wont notice notice much difference unless you get all the exhaust done. the cat on my gen 2 liberty was a twin entree job right where the to header pipes join into one i got quoted $400 for a new one or $400 to repipe the front end with a high flow cat. coupled with the rest of the exhaust it was friggin awesome went hard. i still miss my liberty i loved my baby
l series 2" lift 27"boots s/s snorkel full roof racks.
past ride 92 lib gen2 fwd wit a 2.5 quad cam conversion custom exhaust and cold air induction.
banger
Post by banger » Fri Apr 09, 2010 5:21 am
but this what i got now so it makes it a little better
vincentvega
Post by vincentvega » Fri Apr 09, 2010 8:57 am
allow me to rephrase for clarity
it is not a cat. its a resonator
banger wrote:if the top one has a honey comb in it than it is a cat
Post by AndrewT » Fri Apr 09, 2010 10:25 am
It's hard to tell really with the heat shields there etc. You really have to look inside. If there is honeycomb kindof material there then it's probably a catalytic convertor.
The aftermarket job below it is definitely just a "hotdog" resonator.
However I rekon the top one is just a resonator, not a cat, because with these Libs the cat is normally inbuilt as part of the "Y Pipe" headers that bolt to the motor.
With engine removal methods, I normally find lifting the engine up and out of the bay with a crane to be the easiest....however if it's just the motor you want to remove then I find it easier to separate it from the gearbox in the car then lift the motor out by itself. It's a bastard with the gearbox attached. Lots of pushing, pulling, re-angling etc.
If you want to remove both engine and gearbox then the other method of dropping it all out the bottom is quite easy....but just be aware that you are also removing all the suspension, crossmembers, steering rack - everything all at once. Really handy if you are planning to swap all that stuff out at the same time.
ScubyRoo
Post by ScubyRoo » Fri Apr 09, 2010 12:19 pm
Thanks for your comments everyone. On the exhaust, it is definately a resonator. With the muffler I had on the back of scoobs I think they'll combine pretty well... we'll see in a couple of hours.
Yesterday I was lucky enough for El_Freddo to make the trek down to frankston. My computer is having a little skitz out trying to upload photos, so you'll have to wait for those.
Lots was accomplished! It was great having a super helper like El_Freddo for the day and I'm super grateful - thanks dude!
The entire lift kit is in, all suspension has been moved accross, brakes have been bled, ball joints changed and trailing arms swapped. The steering column was damaged when I dropped the engine out, so they were swapped too. Doesn't sound like much but it was a lot of work involved!
Today it's a matter of engine connections (wiring, air intake, clutch, hill holder etc), reinstalling exhaust and tailshaft, the radiator and bleeding the cooling system, reinstalling head and driving lights and transfering the stereo.
Thanks again to El_Freddo for his help, you're a champion!
Owen.
vincentvega
Post by vincentvega » Fri Apr 09, 2010 2:18 pm
good to hear the car is coming together mate.
ScubyRoo
Post by ScubyRoo » Sat Apr 10, 2010 10:19 am
She runs! After a quick road block of a cut wire - one of the ignition wires was bypassed into the old alarm of the previous owner in scoobs and when I put the engine into Libby I forgot about it. Quickly linked that back up and she started up first time, no hesitation, nothing, just bam! Took a few seconds for the computer to sort itself out and now she's running smoothly and sounding good with the aftermarket resonator and factory muffler combination.
I'm so stoked! I'm heading into school today, so I'll make use of the internet there and put some photos up for you all.
Owen.
maxxair
Post by maxxair » Sat Apr 10, 2010 3:46 pm
YEWW!!!! Go u good thing.
Cheers, Rohan M.
Post by AlpineRaven » Sat Apr 10, 2010 10:23 pm
AWESOME mate... thats good hey.. (congrats!)
Post by El_Freddo » Mon Apr 12, 2010 9:04 pm
Ok, where are these pics pics pics??? Should I upload them for you on my crap internet..?
ScubyRoo
Post by ScubyRoo » Mon Apr 12, 2010 10:18 pm
Face book photo thingy has cracked the sh*ts, might give it another go tonight see how we go!
Post by El_Freddo » Mon Apr 12, 2010 10:32 pm
ScubyRoo wrote:Face book photo thingy has cracked the sh*ts, might give it another go tonight see how we go!
I can't work out how to do that. Although, I was on a Mac when I tired it. Or my privacy settings are too strict.
I'll keep an eye out from them, otherwise I'll try uploading the ones I have for you.
ScubyRoo
Post by ScubyRoo » Sat Apr 24, 2010 2:01 pm
I've been busy the last few weeks with work keeping me away from home, so I haven't had time to work on Libby. Today I finally got a bit of time, so I cleaned up the loom routing, removed the junk remains of the air suspension components and installed the driving lights' wiring.
I've changed the routing of their wiring and relay location - the relay now sits neatly in the space previously occupied by the air suspension lines and bracket behind the left strut tower, with the wiring running through the grommet vacated by the removed air lines. The wiring then follows the loom through the quarter panel and pops out under the main fuse box - nice and neat like its supposed to be there. I need to lengthen the lights' loom now though, as the right line is about 1m short and the left about 30cm.
This term's camps have been non stop, and this week is my final one for the term, so that'll mean I'll have time again to work in Libby - there's a good chance I'll get her over the pits before the trip down to the Otways late next month...
El_Freddo wrote:I can't work out how to do that. Although, I was on a Mac when I tired it. Or my privacy settings are too strict.
Its a feature of Firefox - not sure if you can do it in Safari. Feel free to put some pics up if you have time!
Owen.
ScubyRoo
Post by ScubyRoo » Mon May 03, 2010 11:02 pm
Back dating a few photos for you guys, the results of a busy day with Bennie's help. I'll put up a few more photos later in the week. Put the new stereo in this evening and also removed the broken auto-antenae.
The work table:
'Adjusting' the firewall to accomodate the new struts:
The steering column was pulled through when I lowered the engine out (oops!) you can see how far it pulled out - the dark ring is the normal wear point in the firewall:
The steering column being switched over:
Lookin' good:
EJ goodness:
Outback struts, king springs and engine xmember spacer:
A very busted knock sensor (off the old engine - guessing it got a little hot at some point?!):
ScubyRoo
Post by ScubyRoo » Mon May 03, 2010 11:03 pm
Front end (sorry forgot to rotate):
http://sphotos.ak.fbcdn.net/hphotos-ak- ... 5788_n.jpg
Back end unlifted:
Back end lifted... fuel tank filler, breakline, outback strut, king springs, rear diff xmember:
RubyScoo lookin proud and Scoobs lookin beat up:
Outback vs liberty trailing arm mounts:
Progress:
Clearance - not even a high enough jack to clear the 16s when their on!
A few more to upload but their on a different computer - will put them up later in the week!
I'm hoping to head in for the inspection end of this week!
Owen.
Post by TOONGA » Tue May 04, 2010 1:56 pm
I myself would have used Jarrah blocks to do that not dangerous pine :)
Post by RSR 555 » Tue May 04, 2010 2:02 pm
Yes Jarrah is much harder but can be very expensive over east :(
ScubyRoo
Post by ScubyRoo » Tue May 04, 2010 2:04 pm
yeah but pine moulds to object and you get better surface contact, thus holding the lift better :rolleyes:
