f*&ked clutch or just clutch cable
Post by RSR 555 » Wed Apr 28, 2010 9:39 pm
robo wrote:Heya
Dont want to hijack this thread but when i release the clutch on my wagon the car sometimes shudders particularly on slope, what could that be, it also makes a tink noise when engaging clutch.
cheers
robo
I was going to say you could start your own thread but I'll reply here with what I think it is.. Normally shuttering comes from hotspots (shinny spots from lots of heat) on your flywheel or loose springs in your friction disc and your clicking sounds like one of your retaining clips on your release bearing may have come off.. either way it sounds like you're going to need to inspect the clutch system :(
Creamfeeder
Post by Creamfeeder » Tue May 11, 2010 11:53 am
Finally got around to looking deeper into the issue and I can see what the problem is. I just want to confirm that the clutch box you guys were referring to is the little C shaped thing immediately behind the clutch pedal assembly. Is that right? And are they usually welded into place? From what I can see from looking into it, the tack holding the box to the spar behind it has cracked and it is flexing forward every time the clutch pedal is depressed.. It looks to me like all I need to do is retack that into position and it should be sweet.. Does this sound right to you guys? Bitch of a spot to weld though. any hints?
Post by TOONGA » Tue May 11, 2010 2:13 pm
thats correct you need to unbolt the box take it out of the car pull it apart strengthen it and then rebuild it and put it back in :)
at least thats one job I will be doing this weekend on my brumby:)
I wouldn't try to weld it in the car as you could cook everything under the dash
Post by sven '2' » Tue May 11, 2010 11:15 pm
Very wise words - seen it attempted.
Epic fail...
Sven
Post by TOONGA » Wed May 12, 2010 8:32 am
here is one out of the car (a fun job) (this is my spare)
and this is the area that fails
mind you this is different to the last one I had and this came from an 88 brumby
Creamfeeder
Post by Creamfeeder » Thu May 13, 2010 10:39 am
Thanks for the pics, Toonga, that has cleared things up immensely, thats exactly what has failed on mine. One question though, people have been mentioning welding on some flat bar to strengthen it. Where would I weld this on?
Post by TOONGA » Thu May 13, 2010 1:10 pm
Creamfeeder wrote:Thanks for the pics, Toonga, that has cleared things up immensely, thats exactly what has failed on mine. One question though, people have been mentioning welding on some flat bar to strengthen it. Where would I weld this on?
you would need to pull all of the pedals off weld plates on the internal sides of the box where the cable holds into and on the opposite side
look at this it will help heaps showthread.php?t=11821&page=2
Creamfeeder
Post by Creamfeeder » Fri May 14, 2010 4:07 pm
hi guys, thanks again for all your help, I have managed to pull the offending item out of the car, not an easy job, and now just need to get it fixed. I've attached some photos to show the faults so you guys can give me your opinions.
Post by TOONGA » Fri May 14, 2010 5:02 pm
yep the last one i saw like that i threw in the bin (it was mine) I would concider getting another pedal box but if you can't then you are in for a welding good time and it looks as if someone has welded it up before as those welds are way bigger than the ones on mine ( i just went and looked at it in the shed)
gtcompletepower
Post by gtcompletepower » Fri May 14, 2010 7:51 pm
contact me at http://www.thebrumbyshop.com if you need one i should be able to find you a good one
Creamfeeder
Post by Creamfeeder » Fri May 14, 2010 10:11 pm
bugger.. no hope of a resurrection you dont think? Need to atleast get it semi mobile soonish as I'm moving soon and its currently just parked on the street. you think a quick weld, a little bash and a bit o flat bar would hold it in place for a bit?
Post by TOONGA » Fri May 14, 2010 10:16 pm
yep it would hold for a while but it would be better to replace it with one that wasn't split (and strengthen it before it went in)
Creamfeeder
Post by Creamfeeder » Fri May 14, 2010 10:48 pm
so no chance of a resurrection? a bit of welding, a little bash a nd a bit of flat bar wont hold it together for a bit? need to have it mobile soonish as I'm moving and its just parked on the street at the mo.
Creamfeeder
Post by Creamfeeder » Sun May 16, 2010 10:31 am
yeah fair enough, I definitely want to replace it, but I need to have it mobile for the move, just to get it to the new place atleast. Thanks again for the help guys, you've been indispensable. Hopefully I'll have th little beast going again by mid week.
Creamfeeder
Post by Creamfeeder » Mon May 17, 2010 6:53 pm
So got the welds done today, gonna put it back in tomorrow and hopefully it'll hold up for a while till I can get a newie.
Post by TOONGA » Mon May 17, 2010 9:44 pm
take some photos for future reference it is amazing just how many of these things bust and how few photos there are of a fixed one
Creamfeeder
Post by Creamfeeder » Tue May 18, 2010 12:33 pm
well, its back in the car and, after replacing the dud battery, the brumby is back in the saddle. Thanks again for all your help guys.
Post by TOONGA » Tue May 18, 2010 12:50 pm
well done but I bet you didn't take any photos though did you :)
