I was going to say you could start your own thread but I'll reply here with what I think it is.. Normally shuttering comes from hotspots (shinny spots from lots of heat) on your flywheel or loose springs in your friction disc and your clicking sounds like one of your retaining clips on your release bearing may have come off.. either way it sounds like you're going to need to inspect the clutch systemrobo wrote:Heya
Dont want to hijack this thread but when i release the clutch on my wagon the car sometimes shudders particularly on slope, what could that be, it also makes a tink noise when engaging clutch.
cheers
robo
f*&ked clutch or just clutch cable
- Creamfeeder
Finally got around to looking deeper into the issue and I can see what the problem is. I just want to confirm that the clutch box you guys were referring to is the little C shaped thing immediately behind the clutch pedal assembly. Is that right? And are they usually welded into place? From what I can see from looking into it, the tack holding the box to the spar behind it has cracked and it is flexing forward every time the clutch pedal is depressed.. It looks to me like all I need to do is retack that into position and it should be sweet.. Does this sound right to you guys? Bitch of a spot to weld though. any hints?
- Creamfeeder
- TOONGA
you would need to pull all of the pedals off weld plates on the internal sides of the box where the cable holds into and on the opposite sideCreamfeeder wrote:Thanks for the pics, Toonga, that has cleared things up immensely, thats exactly what has failed on mine. One question though, people have been mentioning welding on some flat bar to strengthen it. Where would I weld this on?
look at this it will help heaps showthread.php?t=11821&page=2
- Creamfeeder
hi guys, thanks again for all your help, I have managed to pull the offending item out of the car, not an easy job, and now just need to get it fixed. I've attached some photos to show the faults so you guys can give me your opinions.
- DSCN0588.JPG (61.52 KiB) Viewed 4916 times
- DSCN0578.JPG (67.54 KiB) Viewed 4915 times
- DSCN0576.JPG (63.52 KiB) Viewed 4915 times
- DSCN0590_01.JPG (68.45 KiB) Viewed 4917 times
- TOONGA
yep the last one i saw like that i threw in the bin (it was mine) I would concider getting another pedal box but if you can't then you are in for a welding good time and it looks as if someone has welded it up before as those welds are way bigger than the ones on mine ( i just went and looked at it in the shed)
- gtcompletepower
contact me at http://www.thebrumbyshop.com if you need one i should be able to find you a good one
- Creamfeeder
- Creamfeeder
- Creamfeeder
- Creamfeeder
- Creamfeeder
