Just some backyard fun. Video 3.7mb
Just thought I'd throw a link in here to the lastest video I done. Sorry about the quality, my bro only had his Picture Camera, not my DV... Also the lack of sound.
Warning, it requires DivX 5.2 and a player like WMP, Quicktime or WinAmp.
www.offroadingsubarus.com/downloads.html
yeah, problem with 2" lift and 27's... suspension is too stiff. I would like to soften it up and grab a 4 or 6" lift, maybe get new front long rides and some different shocks for the rear.
Nice work ... looks like you need to weld your rear diff
On the body lift side of things, think very carefully before you do go anything above 3". I found with my old 4" lift I was bending the blocks and bolts ( especially at the rear ). I think anything 4" and above should be re-inforced between the blocks. Some of the guys in the US ( usmb ) have done some really cool kits that are almost like a subframe.
However I do push my subaru's way past their capabilities offroad, so that would have had a hand in the bent lift blocks. I am the only person i know to have bent a re-inforced diff hanger
My current rig is 3" front, 2" back and fits the 27" wrangler tg under without scrubbings which is all that's really needed.
Just out of interest
any thing bigger than 2" in SA is illegal and voids all insurance policies on the car including the compulsary 3rd party bodily insurance.
a 2" is legal only when the car has been pre-approved by transport SA and inspected after installation then fitted with a mod sticker.
You will then be given a certificate of exemption for that car which you have to carry around for when you get pulled over.
same with your rims/tyres. The speedies are out of track for sure and the total tyre size is more than 10% greater the the OEM fitment.
Yeah. I know all that mate. I am pretty sure the lift kit has been approved but I will have to double check that. Also my insurance company knows I have a 2" lift kit and they didn't seem to bother me about it. But still, I'll give them a ring again about the wheels, not that they are at all legal
But this topic is in the Videos forum, and is about a video. Can we go back on topic?
Indeed. Tis a good video Phizinza - your Brumby looks the shizPhizinza wrote:But this topic is in the Videos forum, and is about a video. Can we go back on topic?
- tim_81coupe
Yeah tim, I have a spare 3.7 diff from a wreck. My bro wants to weld it and see what its like. I guess when we get the mig I will give it a go. It was frustrating with no LSD or weld
But a run up makes it work.
I must admit, I have zero expirance in offroading. I just think it over and use the most logical answer to get thru. Speed.
I need to get my other (tame) video off my DV cam and edit that up. I really should do some more offroading and try some harder stuff.
"when one of the wheels is off the ground"
Yeah, because the diff is basicly turned into a soild axle. So both wheels *should* turn the same no matter what
*should*, I have read plenty of stories about breaking welds..
I have also talked to plenty of people over the internet that say LSD is great for offroad. So if I get one or two people saying LSD's are crud, I won't belive a word till they explain why. Some people just have beliefs.
I still believe having all these extras only makes it easy for the driver. Better drivers shouldn't need all this cool stuff? i.e. I know my dad used to take his VW passat (front engine, FWD) places hilux drivers wouldn't go, or get stuck.
- tim_81coupe
I have broken CV's and axle splines with my diff. This comes about from driving around on the road with both rear axles in, I drive with one now.
LSD's are certainly heaps better offroad than an open diff. And when I say heaps I mean heaps. Basically it greatly raises the threshold at which slippage will occur. In a one wheel airborne situation however I have seen them slip. In fact I've rarely seen a wheel in the air on an LSD vehicle not get all the power. The only LSD equipped vehicle I've seen in WA able to drive with a wheel in the air easily has been the Jaffa-tank with its viscous LSD. Hatchie slips like crazy :P :P .
Welded is definitely the go for hardcore offroading, short of spending the dosh to get a proper locker. If you want proof of that there is a video floating around in which jonno from these boards manages to tip his car on its side by driving up a hill! He'd have never got that far without the welded diff...
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Here we go again.... the LSD vs CIG debate....Fang wrote:Others will tell you why LSD is not good offroad - but mine has been quite good offroad - helped get up some daunting hills.
A welded diff has the advantage when one of the wheels is off the ground - I am lead to believe.
with the welded diff, YOU WILL CHEW UP SHAFTS (or worse!), unless you remove shafts when you drive onroad.
LSD's work fantastic offroad, provided its a clutched unit, and provided that you have it serviced (read: repacked) every 12-18 months. Ive seen them work in other's cars, and you can't beat them in sand, mud or even rock-hopping situations. (ok, a locked one would...
mine worked gloriously offroad. onroad, it even behaved a bit like a locker....chirped around corners driving around in carparks!!! (for the first several months)
viscous LSD are slow on the uptake. more suited for road use, to minimise damage to drivetrain (ie driveshafts).
Sure a welded diff is more advantageous in offroad situations, but buggered if I will be removing/putting in shafts, only to lay under a dirty car, in mud, sand rocks, having crap drip on my face, only to hop back into my (relatively) clean interior and muck all that up.
1998 Subaru Legacy GTB
speaking to a friend at the mechanic saw my L series chirping a rear wheel when i parked (clutch type LSD) and said that it all depends on the oil you use. He said if you use 80wt oil with no friction modifier it will basically be a locked diff.
havent tried playing at all yet because im pretty happy with it currently. It does definetly put more power to the lifted wheel but i think i can spin a rear wheel with the other one lifted if i try. (but ive got road tires not 4wd)
I cant play it
I have sound but no video, im using winamp 5.12 and have also tried media player xp but no show.
What do i have to download to watch this clip
Cheers guys
Gannon.
Cheers guys
Gannon.
Thanks fang.
Indeed you do need the divx codec. And the reason the sound is playing is because I just use normal MP3 for it. But thats the technical side of it. My new videos will be done in DivX 6... My PC stuffed up and I had to download all the new codec's, including the new WMV one. Its a pitty, cos now people have to download something like 10mb just to watch my vids
I could do them in WMV so they should play in any WMP. What do people think. I asked this on USMB but a few guys said "NO" cos they use linux. I can't do both, not enough space on my site for that.
- BaronVonChickenPants
See if this takes care of the divx issues, it's only 450k.
http://www.divxlight.com/divxlight.exe
Jordan.
Jordan.
