Subaru Liberty 1993
Kappage
Subaru Liberty 1993
Post by Kappage » Sun May 04, 2008 5:42 pm
Hi i am new to this forum and i need some help with my car. Since my car is an AWD it has a split axle at the front of the car and on the drivers side on the end at the Transmission it has been Weeping Transmission oil, so today my dad and i finally got around to taking it apart (we have a manual for the car) we have done everything it has asked and cant find the seal!!! Here are some photos.
The rubber Boot seems to be intact so that wasn't leaking. Here are the pics
Can some one who has had experience with this car tell me where abouts the rubber seal is?
Thanks for being patient and for all your help!!!
(sorry if i got some details wrong)
Post by AlpineRaven » Sun May 04, 2008 5:57 pm
The rubber seal is behind the cup - it says "NOR" in last photo if you can see it - thats the rubber seal, you will need to remove the cup cover off and count how many turns before you remove it - its a hard job to remove the cap because its very tight fit and really you're suppose to use special tool for that... CBC sells these rubber seals if you take it to them.
Kappage
Post by Kappage » Sun May 04, 2008 6:02 pm
So you are saying that Twist the thingo that says NOR and make sure i count how many complete rotations it takes to take it out?
EDIT***
Can you also tell me if it is reverse thread? or jsut standard
Thanks!
Matatak
Post by Matatak » Sun May 04, 2008 6:12 pm
Standard thread. use a punch on some of the notches and a Hammer to tap it round.
dont forget about the Locking Tab they have held in by a 12 or 14 mm bolt IIRC
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Kappage
Post by Kappage » Sun May 04, 2008 6:24 pm
What do you mean by locking tab??
Post by AlpineRaven » Sun May 04, 2008 8:11 pm
Kappage wrote:What do you mean by locking tab??
There is a toothed locking tab it is shown in the photo there is a 14mm bolt attached to it, you need to remove the bolt first before you can remove the locking tab.
Post by AlpineRaven » Sun May 04, 2008 8:12 pm
Kappage
Post by Kappage » Sun May 04, 2008 8:21 pm
Is this the locking Bolt?
Post by AlpineRaven » Sun May 04, 2008 8:53 pm
Kappage wrote:Is this the locking Bolt?
Yep correct.
Post by El_Freddo » Sun May 04, 2008 9:00 pm
That's the one, the little plate there will come off with it. Mark where the cap is now with a line, then count the number of turns, make sure you keep a marked tally on a piece of paper or with chalk on the gearbox. I forgot how many turns I did getting it off, so I tried to get it right by "feel". Pretty sure I havn't but its still going without any problems after two years and 80,000km...
Good luck with it.
Kappage
Post by Kappage » Sun May 04, 2008 11:27 pm
Thank you all very much with your help i will be doing this tomorrow afternoon if i get time with all the study i have to do.
liberty92
make sure its not
Post by liberty92 » Mon May 05, 2008 7:22 am
the bung in the inner cv leaking and not the seal
yarney
Post by yarney » Mon May 05, 2008 9:31 am
liberty92 wrote:the bung in the inner cv leaking and not the seal
I agree have a look in the female end of the cv there will be grease in there but there shouldn't be but you do have a weeping seal
Kappage
Post by Kappage » Mon May 05, 2008 10:09 am
Can you please elaborate? I am very new to this whole concept, i really should of done automotive this year. But then again the automotive class didnt really learn much...
Kappage
Post by Kappage » Sat May 10, 2008 3:56 pm
Well i have finally gotten around to doing it, The thing that looks like a sprocket went around 4 times and 3 teeth. I will have to wait until monday to get a replacement bung and seal, then i will get it back together ASAP. Also when i took out the split pin on the drive shaft Do i need to buy a new one or jsut put the old one back in their?
Post by El_Freddo » Sun May 11, 2008 1:53 am
You can get a new one if you want. Being a poor uni student (but still somehow manage to have some fun at times) I use the old split pin without any dramas yet - they've been taken out twice since I've had the car for the past 3 years - no movement yet...
Kappage
Post by Kappage » Sun May 11, 2008 8:11 pm
Thanks for the headsup, What university? Im looking at either going to Curtin or UWA depending on my TER
