Dual shock mod question
Prunes
Post by Prunes » Wed Apr 30, 2008 2:54 pm
Hey all, Thinking about the dual shock mod, Is there any reason why the second shock is mounted behind the coilover? as I'm thinking on my brumby when I do the L series control arm mod the struts will be angled forward at the bottom so wouldn't it be more benificial to mount it in front of the coilover?
2002 Impreza GX Hatch: Dents, Scratches, Missing inside wheel arch, Barely attached front bumper.
1983 Brumby: Currently being rebuilt.
bluesteel
Post by bluesteel » Wed Apr 30, 2008 3:06 pm
mount it wherever you like trent
just make sure its on the same angles as the other shock and nice and solid
Ben
Post by Ben » Wed Apr 30, 2008 5:26 pm
Can I ask why you want to do this mod?
Please watch before posting!
bluesteel
Post by bluesteel » Wed Apr 30, 2008 8:39 pm
if you have seen the way he drives you would know the poor shockies need all the help they can get ;)
Post by El_Freddo » Wed Apr 30, 2008 10:25 pm
bluesteel wrote:if you have seen the way he drives you would know the poor shockies need all the help they can get ;)
Hehehe... I like the sound of that!
plucky
Post by plucky » Wed Apr 30, 2008 11:44 pm
If you still have the '83 front struts, strip them wash them out, and refill them with 20 weight motorcycle fork oil or auto trans fluid. Auto trans fluid is roughly equivalent to 10 weight fork oil. In my mind a far superior solution than adding extra shocks. See my previous post on this for more detail.
Prunes
Post by Prunes » Thu May 01, 2008 9:02 am
Yeah I do tend to drive a tad fast offroad, I just love the corrigated dirt tracks massaging my back, now I just need to make the car survive them a little easier
discopotato03
Post by discopotato03 » Wed May 07, 2008 9:27 am
Hopefully I will soon have the answer to the L rear strut woes in the form of a Koni with Toperformances coil over height adjustable spring platform .
I don't know if it will suit a lifted L/MY but at least the damping will suit an ~ 200 in/lb rated spring in the std L diameter .
BTW 1st gen RX Turbos use 180 in/lb springs and wagons are supposed to be 196 .
A .
