AWD Boxes
Suby Roo
AWD Boxes
Post by Suby Roo » Thu Apr 17, 2008 8:59 am
One question..
Are the AWD 5 speed, Dual range gearbox out of a 92 liberty meant to make a slight whine all the time??
FROG
Post by FROG » Thu Apr 17, 2008 9:47 am
I Dont Think Its Meant To, Mine Does It Too,if The Bearings Are A Little Worn Then The Gearsets Dont Line Up As They Should Result Is The Whine
Suby Roo
Post by Suby Roo » Thu Apr 17, 2008 10:18 am
Does this damage the Box at all after a while? Or should it be fixed?
FROG
Post by FROG » Thu Apr 17, 2008 10:40 am
Well Mines Been Like It For 60 000 Plus Klm And I Dont Think Its Getting Worse The Bearing That I Think Is The Culprit Is Very Expensive
Post by AlpineRaven » Thu Apr 17, 2008 9:25 pm
I think mine does that as well, pfft I dont mind and I will be rebuilding AWD gearbox sometime soon anyway (have gearboxes ready for rebuild)
mattl200
Post by mattl200 » Fri Apr 18, 2008 12:54 pm
that would be the top shaft rear bearing last i priced one $160-180 i think
when it starts to rattle on deceleration its stuffed
and the whole box has to come apart to change it
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Apr 18, 2008 9:00 pm
As above, i have seen many that are only just a bearing and fall apart when the box is split
The long road ahead
