Speedo cable
Brownster
Speedo cable
Post by Brownster » Tue Apr 15, 2008 7:01 am
My speedo has stopped workiing this morning. Just wondering from everyones experience with a WRX converted Brumby whats the best way to obtain a new one and would it be a modified one with a WRX gearbox end to a Brumby dash fitting...
Any info much appreciated.
'Brownster'
Was that just a Brumby ute that flew past?
Post by AlpineRaven » Tue Apr 15, 2008 10:27 pm
Was the speedo from WRX or Brumby's original one?
Post by Alex » Tue Apr 15, 2008 10:30 pm
your obviously running a WRX box then?
and is the car lifted?
Matatak
Post by Matatak » Tue Apr 15, 2008 11:39 pm
is the speedo cable actually screwed?
my bet is that its got the original Brumby one in there.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by AndrewT » Tue Apr 15, 2008 11:56 pm
Most likely you have a Brumby dash cluster and a WRX gearbox. You probably still just have the original Brumby speedo cable.
It could have snapped somewhere along the line (this occasionally happens), or possibly it's just fallen out of the back of the dash.
Check if it's fallen out, if it hasn't remove the speedo cable and turn the gearbox end of it - see if it turns at the other end. If it doesn't then it's snapped.
Just get a replacement speedo cable and you should be right.
Brownster
Post by Brownster » Wed Apr 16, 2008 6:23 am
Thanks heaps for the replies guys. It is a WRX gearbox to an original Brumby dash. Havent had time to check the actual cable. Will be doing that Thursday...
'Brownster'
Brownster
Post by Brownster » Thu Apr 17, 2008 10:30 am
I have pulled it out and the cable is broken. Does anyone have a part number from Subaru on these otherwise i have a company in Sydney that makes them.
'Brownster'
FROG
Post by FROG » Thu Apr 17, 2008 10:54 am
Brumby Speedo Cable Is 737411001 And Retails For Around 53.20
Brownster
Post by Brownster » Thu Apr 17, 2008 11:55 am
Thanks Heaps will cal Subaru now..
'Brownster'
FROG
Post by FROG » Thu Apr 17, 2008 12:05 pm
Ah Hummm 02 69641177 :-)
Post by El_Freddo » Thu Apr 17, 2008 12:12 pm
FROG wrote:Brumby Speedo Cable Is 737411001 And Retails For Around 53.20
FROG wrote:Ah Hummm 02 69641177 :-)
^ "See FROG for all your subaru spare needs"
