10 points on offer
LongtimeAddict
10 points on offer
Post by LongtimeAddict » Mon Apr 14, 2008 6:44 pm
10 points to the first person to tell me why i have installed these switches???
Switches $8 from SupaCheap
Bout 25 mins to install and wire up
:D:D:D:D:D
99 Outback (stock at the moment) :rolleyes:
schultzie
Post by schultzie » Mon Apr 14, 2008 6:53 pm
thermo fan, and spot lights or a starter switch
L-series Ea82t, WAIC+BOV 1Bar, 15's, 5sp dr, WOLF3D V4+, =D
LongtimeAddict
Noooooooo Bingo!
Post by LongtimeAddict » Mon Apr 14, 2008 6:55 pm
Sorry not even close.................
INEEDABEER
Post by INEEDABEER » Mon Apr 14, 2008 6:56 pm
Ejector seat,machine guns and seat vibrator!
]Hey I know Jack Schitte!
[/SIZE]
schultzie
Post by schultzie » Mon Apr 14, 2008 6:57 pm
centre diff lock and rear diff lock
brumbyrunner
Post by brumbyrunner » Mon Apr 14, 2008 6:58 pm
fill some ugly holes in your dash!
LongtimeAddict
still Noooooooooo Bingo!
Post by LongtimeAddict » Mon Apr 14, 2008 6:59 pm
Hint - 1 black switch 1 green switch
Post by Gannon » Mon Apr 14, 2008 7:00 pm
brumbyrunner wrote:fill some ugly holes in your dash!
Hahahahahahha!
My starter/horn immobilizer idea?
Fuel pump/injector or ignition cut
Do we get money or rep points?
LongtimeAddict
still Nooooo bloody Bingo!
Post by LongtimeAddict » Mon Apr 14, 2008 7:03 pm
Points only.
Hint 2 - I have an MPFI L series
Cam
Post by Cam » Mon Apr 14, 2008 7:18 pm
check engine light...
Post by El_Freddo » Mon Apr 14, 2008 7:18 pm
Ignition - one switch for switching the ignition on, the other to start the car.
OR
One to kill the fuel pump, another to kill the ignition and two other hidden switches to make things interesting...
Post by Gannon » Mon Apr 14, 2008 7:24 pm
Fast idle?
Cam
Post by Cam » Mon Apr 14, 2008 7:27 pm
The ea82 mpfi do have the check engine plugs under there dont they?
Ben
Post by Ben » Mon Apr 14, 2008 7:44 pm
green check connector switch and black check connector switch. That is the height of subie nerdiness by the way...
Please watch before posting!
LongtimeAddict
10 points to Cam
Post by LongtimeAddict » Mon Apr 14, 2008 7:45 pm
Yep I got sick of pulling the panel off to check codes, reset etc. so I just wired the black and green plugs to switches and bingo - check codes at the flick of a switch! ;););)
And yes I guess i'm a subie nerd!!!! lol :p:p
Post by El_Freddo » Mon Apr 14, 2008 8:03 pm
LongtimeAddict wrote:I just wired the black and green plugs to switches and bingo - check codes at the flick of a switch! ;)
I should have known that - I've got an MPFI, even though the ECU is still wired in and trying to operate and the MPFI is on a bench in pieces it still pushes out codes - no temp sensor or crank angle sensor.
I wonder if i could wire these things up to operate off the carbie engine. I would imagine it a waste of time any way it goes...
Post by Gannon » Mon Apr 14, 2008 8:11 pm
Well done Ben, although i think the height of subaru nerdiness is also extending the LED so its easier to see.
Post by Alex » Mon Apr 14, 2008 8:19 pm
NEONS!!!!! :D :D
CPOCSM
Post by CPOCSM » Mon Apr 14, 2008 8:23 pm
Alex wrote:NEONS!!!!! :D :D
Nah - strobes!!
Means you wouldnt miss the code flashes!!
Hooroo
Rob Forsyth
timmo
Post by timmo » Mon Apr 14, 2008 8:41 pm
why are you getting so many CELs?
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
