EJ20 Crossmember
Raymondo
EJ20 Crossmember
Post by Raymondo » Sat Mar 15, 2008 11:04 pm
About to fit an EJ20 into my 89 brumby,What engine crossmember have people had success with?
Also has anyone fitted a version 3 (97) impreza steer rack to a brumby?
Any help would be great:)
legacytt
Crossmember
Post by legacytt » Sun Mar 16, 2008 12:21 pm
You can use the standard crossmember, you may need to file the engine mount holes a little to allow the EJ bolts to slot in. You will need to stick witht the MY steering rack as the EJ ones are a different size/length.
Post by AndrewT » Sun Mar 16, 2008 2:08 pm
If it's a turbo motor you will need to cut a concave hole out of the standard crossmember to clear the turbo up pipe. Otherwise you could try to source a very rare EA81turbo crossmember.
Matatak
Post by Matatak » Sun Mar 16, 2008 3:36 pm
Imprezza steering rack will actually fit.
but there is mods needed to do it and it is in no way a 'bolt in' job.
the Rack ends are going to be to long to use so either source new shorter ones or cut and reweld shorter. (MY ones wont work)
the steering extension between S.wheel and Pinion on the rack needs to be around another inch longer.
the hole for the pinion to go through in the cross member needs to be enlarged.
the mounts off the Imp. rack needs to be used and the holes on them slotted inwards.
use the original bushing for the passenger side mount and you can squeeze the Imp. bush around the drivers side mount on the rack.
a little bit of rebending ont he lines on the rack itself may be required also.
it takes time, money, file, welding, and etc to do but is doable.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Raymondo
Post by Raymondo » Mon Mar 17, 2008 7:43 pm
What if I were to use the impreza crossmember.Any ideas on that.
PeeJay
Post by PeeJay » Mon Mar 17, 2008 7:50 pm
That's way harder - unless you are a very skilled welder/fabricator don't even think about it.
