fitting windscreen how much sealant?
timmo
Post by timmo » Fri Mar 14, 2008 11:59 am
finally got round to fixing the rust around the windscreen in the L series. Anyway I bought a tube of selleys d-mastic in town the other day to put the windscreen back in with but suddenly thought 1 tube (standard caulking gun size) might not be enough? I dont want to start then to run out anyone know how much i'll need???
cheers, timmo
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
Suba
Post by Suba » Fri Mar 14, 2008 5:32 pm
Do not use mastic, use eurothane , bostic is best.One tube should be plenty
Mike.
timmo
Post by timmo » Fri Mar 14, 2008 7:17 pm
what will happen if i use the mastic? ie will it do the job? Dont know when i'll be in town next Its 2 1/2 hours return!
GU Patrol Ute
Honda XR400R
Suba
Post by Suba » Fri Mar 14, 2008 7:47 pm
For one ,mastic is not a glue and is only ment for sealing windscreens fitted in rubber ,such as the MY model Subaru's.
You need to use eurothane , that is what they are fitted from factory with and what all windscreen fitters use to fit bonded windscreens with such as the LSeries Subaru.
Mike.
timmo
Post by timmo » Sat Mar 15, 2008 7:47 am
ok then thats what i needed to know the counter jumper gave me the wrong product. I'll put it off for a while
GU Patrol Ute
Honda XR400R
