Loose cv stub
- stamp_licker
Loose cv stub
L series related.I've got a front cv that can be pushed out by hand from the wheel bearings.It appears the washer had slipped under the casle nut and the hub had become loose.Tightening the nut did nothing to stop the play in the hub.I'm thinking the bearings are flogged,but am also wondering if the cv stub can be worn down so it is no longer a tight fit in the bearings.
Building a hardcore postie:D
something a bit side tracked.. is it "rusty" look around that area? where about it has been rubbing metal to metal with dirt/sand/soil & water?
- Suby Wan Kenobi
- stamp_licker
