1.5:1 EA Part Time Lo into EA Full Time
BrennyV
Post by BrennyV » Mon Feb 25, 2008 5:00 pm
Ok been searching around and seen a few people now running the 1.59:1 PT4WD reduction gear in there EJ boxes, just want to know if anyone has also performed this on there EA FTAWD gearbox and any pros or cons of the process.
Thanks
Brendan
Hunter S. Thompson
brumbyrunner
Post by brumbyrunner » Mon Feb 25, 2008 8:02 pm
I had that mod done to my white Brumby around 1994. I cannot help you with the tech though, only that it's a good thing and it works.
Settlement Creek Racing
PeeJay
Post by PeeJay » Mon Feb 25, 2008 8:09 pm
The EA swap is a straight bolt in job. Very easy, highly recommended!
Post by El_Freddo » Mon Feb 25, 2008 8:33 pm
PeeJay wrote:The EA swap is a straight bolt in job. Very easy, highly recommended!
As peejay said. So easy that i want one. The hardest bit is finding an EA FT4WD gearbox to start with...
Have fun.
(the jealous one)
discopotato03
Post by discopotato03 » Mon Feb 25, 2008 9:02 pm
You need to change the 1st motion (input) shaft and the double idler and the low range driven gear if your starting with a dual range full time L box .
If yo have a single range AWD L box then you need to find a set of dual range casings and all of the above PLUS the dual range main shaft .
The third possible combination is an AWD L box with the closer ratio N/A gear set and either ratio dual range gears .
I think to do this you need the EJ gear set , EA input shaft/gear , place all the EJ counter shaft gears on the L AWD counter shaft .
This last combination is what I should have had fitted to my converted DR Vortex box for DR+AWD+ closer ratios+taller low range . If I can find an early AWD Lib box with the closer ratios I may grab that .
Cheers A .
Post by El_Freddo » Mon Feb 25, 2008 10:12 pm
discopotato03 wrote:The third possible combination is an AWD L box with the closer ratio N/A gear set and either ratio dual range gears .
Which gearbox (lib) are you talking about here Adrian? And does this give you the option of changing the dif ratio and retain the lockable central diff? I'm yet to get my hands on one and pull it apart to have a good look at it to see what can and cannot be done...
Sorry for the hijack.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Feb 26, 2008 1:16 am
L series to L series internals is an easy swap over and well worth it.
The long road ahead
discopotato03
Post by discopotato03 » Tue Feb 26, 2008 5:52 am
Bennie that I have to find out in the 1st gen manuals .
The L/Vortex AWD front diff pinion is unique amongst Subaru gearboxes - its because these are shorter than EJ AWD ones and the diff lock is in front of the center diff (L/Vortex) where the viscous coupling is behind it (EJ) . Also the hollow outer countershaft is to suit the L/Vortex diff lock which is a sliding coupling dog clutch .
Gee has someone in Victoria who can change the pinion gear on the pinion shaft if you wanted to go to the expense - possibly Modena not sure .
Will try to give Gee a bell later this morning , cheers A .
BrennyV
Post by BrennyV » Tue Feb 26, 2008 10:01 am
brumbyrunner wrote:I had that mod done to my white Brumby around 1994. I cannot help you with the tech though, only that it's a good thing and it works.
thats good to hear! looks like im pulling out the ftawd box ;) sik of my ghey lo range :P
Hunter S. Thompson
BrennyV
Post by BrennyV » Tue Feb 26, 2008 10:07 am
discopotato03 wrote:You need to change the 1st motion (input) shaft and the double idler and the low range driven gear if your starting with a dual range full time L box .
All i know is that its a ea 3.7 awd box with the option of lo range and diff lock? didnt know there was a dual range ea awd box?
Brendan
Hunter S. Thompson
BlackMale
Post by BlackMale » Tue Feb 26, 2008 10:15 am
BrennyV Isn't yours a dual range? (just without the lower gearing from what i understood from this thread).
BrennyV
Post by BrennyV » Tue Feb 26, 2008 10:22 am
i have the option of awd? or just lo range?
Hunter S. Thompson
BlackMale
Post by BlackMale » Tue Feb 26, 2008 10:26 am
BrennyV wrote:i have the option of awd? or just lo range?
Are you asking (with the ?) or telling?
BrennyV
Post by BrennyV » Tue Feb 26, 2008 10:29 am
Well more confused than anything my friend.
put simply I would assume single range as I’m always in awd and I can pull the leaver up into lo? or back into awd
Brendan
Hunter S. Thompson
bluesteel
Post by bluesteel » Tue Feb 26, 2008 10:40 am
the dual range ea awd box is awd all the time..
you have the option of using the centre diff locker
and the option of using the low range gears
if its the single range box then you only have the option of the centre diff locker
Post by El_Freddo » Tue Feb 26, 2008 10:49 am
BrennyV wrote:Well more confused than anything my friend.
Brendan
Brendan,
I'll take your Ea gearbox in question and i'll let you know what it is :mrgreen:
BrennyV
Post by BrennyV » Tue Feb 26, 2008 11:10 am
bluesteel wrote:the dual range ea awd box is awd all the time..
got cha!
its a dual range then
Bennie, no probs mate. leave the dosh in the glove box ;)
Hunter S. Thompson
BrennyV
Post by BrennyV » Tue Feb 26, 2008 11:12 am
i spose now its just time for the tech side of things :confused:
Hunter S. Thompson
Post by El_Freddo » Tue Feb 26, 2008 12:29 pm
BrennyV wrote:Bennie, no probs mate. leave the dosh in the glove box ;)
Are IOU's accepted? Or do a Homer thing and write "dosh" on a piece of paper???
What tech stuff are you after? You mean splitting the box and swapping the lo ratio gears?
I've never done it, only all talk on this topic unfortnately.
Have fun.
BrennyV
Post by BrennyV » Tue Feb 26, 2008 12:31 pm
yeh same. want to make sure i do it all right ;)
Hunter S. Thompson
