Engine differences
ORX-18
Engine differences
Post by ORX-18 » Sun Feb 17, 2008 4:45 am
I need to know if there is a definite difference between an EA82T and non T engine BLOCK/CRANKCASE. I have found that my problems with the current engine are due to twisting the block so i need a new one asap so i can get it back on the dyno.
To combat this im going to introduce more dowels and studs, ill keep u informed on how it goes :)
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Feb 17, 2008 9:36 am
The non turbo blocks do not have the extra vent at the rear of the crank case for ventilation. Thats pretty much it.
The long road ahead
Post by Gannon » Sat Feb 23, 2008 4:51 pm
But non turbo MPFI blocks do have that vent/seperator thingy
twisting the block, wow
SubaRute
Post by SubaRute » Sat Feb 23, 2008 7:37 pm
whats you location i have a short block and some EA82T bits/spares
complete motor dis assembled
contact 0417623931 leon
Post by El_Freddo » Mon Feb 25, 2008 12:35 pm
Suparoo wrote:But non turbo MPFI blocks do have that vent/seperator thingy
Correct. I dunno if they have a spot for the knock sensor though. The MPFI non turbo's don't have a knock sensor, but from what i have read i believe the turbo's do run the knock sensor...
PS, would like to know what you were doing to the engine to twist the block!
discopotato03
Post by discopotato03 » Mon Feb 25, 2008 8:14 pm
I am 90% sure the later NA MPFI blocks have the tapped hole for the knock sensor just no probe .
Cheers A .
Suby Wan Kenobi
Post by Suby Wan Kenobi » Tue Feb 26, 2008 1:28 am
I have not ever seen an NA EFI block in the workshop, the only EFI i see in an EA is a turbo one.
As for knock sensor i remember the mark on the block but i dunno if the thread is there for the knock mount
The long road ahead
Post by Gannon » Tue Feb 26, 2008 5:26 am
Australian MPFI's were avaliable between 88 and 90 in the touring wagons. They had the 4 plug ecu system
SubaRute
Post by SubaRute » Tue Feb 26, 2008 5:38 am
did you get the pics i emailed you ?
cheers leon
