EA82 HP vs EJ18 HP? & NSW Rego Q
maddog
Post by maddog » Fri Feb 08, 2008 8:04 pm
Hi All - To all the tech heads out there, can anyone tell me what sort of horsepower I can expect from my EA82 in fairly stock form, and what the benefit would be if I stuck in an EJ18? Has anyone in NSW put an EJ20 into their L Series and then had it passed for rego?
Thanks!!!
88 GL Touring Wagon - getting better all the time... or was until Skippy got in the way one night... writeoff now :(
98 Forester - wotaluvlycar! (belongs to missus) ;o)
91 Liberty Wagon in immaculate condition - can't believe how much nice it is, mine! ;)
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Feb 08, 2008 8:24 pm
Yeah Ben has done an EJ20 NA into his L series wagon. The EJ18 or EJ20 is a good re powering of an L series and i think the Ej18 is rated at around 72kw
The long road ahead
Post by Alex » Fri Feb 08, 2008 8:42 pm
newer more re-fined motor, efi, etc, wil always be a shitload better than the standard carby.
I think subaMike use to run a EJ18 in his old MY, and from what i heard it went like a shower of shit both on and off-road.
PeeJay
Post by PeeJay » Sat Feb 09, 2008 9:39 am
If you're going to do an EJ18 you might as well do the EJ20, I believe it's all the same, and no hassles with rego either.
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sat Feb 09, 2008 9:46 am
Mikes EJ18 powered MY certainly was an eye opener on how much better it was then the EA81
The long road ahead
Post by AndrewT » Sat Feb 09, 2008 2:49 pm
EJ18 would be ideal to avoid problems at the rego inspection because it's the same capacity.
They don't have a dyno there so wouldn't know how much extra HP its putting out anyway
PeeJay
Post by PeeJay » Sun Feb 10, 2008 11:41 am
AndrewT wrote:EJ18 would be ideal to avoid problems at the rego inspection because it's the same capacity.
In NSW you are allowed a 15% increase in engine capacity as an owner certified mod, so there are no problems going from a 1.8 to a 2.0
discopotato03
Post by discopotato03 » Sun Feb 10, 2008 2:58 pm
I would still check with the NSW RTA because I think I remember the formula changing from the 15% in capacity to a difference in output . The reason being that they may not mind you going from EA71 to EA81 but EA81 to Honda S2000 could upset them . Capacity is not a reasonable reflection on output anymore .
Cheers A .
PeeJay
Post by PeeJay » Sun Feb 10, 2008 8:13 pm
I went from an EA82T to an EJ20G with no problems.
SUBYDAZZ
Post by SUBYDAZZ » Mon Feb 11, 2008 8:52 am
discopotato03 wrote:I would still check with the NSW RTA because I think I remember the formula changing from the 15% in capacity to a difference in output . The reason being that they may not mind you going from EA71 to EA81 but EA81 to Honda S2000 could upset them . Capacity is not a reasonable reflection on output anymore .
Cheers A .
They don't care what the output is, it is only the capacity, you may put a Honda S2000 motor into a car that was an EA81/82 if your heart so desires. As long as the emissions are same or better and all the anti-pollution gear is retained and no major structural changes take place it is an "Owner Certified Modification" as Peejay says.
Look here: http://www.rta.nsw.gov.au/registration/ ... v_2007.pdf
P.S: the others are here: http://www.rta.nsw.gov.au/registration/ ... i_dl1.html
SUBYDAZZ
Post by El_Freddo » Mon Feb 11, 2008 3:52 pm
Would the MPFI wiring and computer beable to run an EJ18 or EJ20 without any troubles? I'm guessing the sensors would need to be changed on the engine to those from the MPFI wiring harness?
Ideas/suggestions/knowhow?
PeeJay
Post by PeeJay » Mon Feb 11, 2008 3:55 pm
Totally different, it's far easier to just graft the EJ loom+computer into the existing wiring. From memory there are only about 8 wires or so that need to be joined.
Dutchy
Post by Dutchy » Tue Feb 12, 2008 11:34 am
EA82 carby has about 84hp @ 5200
EA82 mpfi has about 97hp @ 5200
EA82T has about 111hp @ 5200
The Ej18 has about 110 hp (82 kW) @ 5600 rpm.
Post by El_Freddo » Tue Feb 12, 2008 3:01 pm
Dutchy wrote:EA82 carby has about 84hp @ 5200
Any idea on the EJ20 or EJ22?
Dutchy
Post by Dutchy » Tue Feb 12, 2008 4:51 pm
El_Freddo wrote:Any idea on the EJ20 or EJ22?
I had done a little research on the EA engines but i found it hard to find the power curves of the ejs mainly because they were used in so many of the new model subs and they all had diffrent powers to suit the car... i managed to find a little though.
The Ej20 rangers between 183kw to 210kw (280hp) but thats most of the turbo charged engines out of liberties. Im not sure on the basic engines
The Ej22 has about 100kw (130hp) for the basic engine unsure on the turbo but i think they have around 200kw but im not entirely sure.
Cam
Post by Cam » Tue Feb 12, 2008 5:12 pm
N/A motors
early ej20 92kw
middle ej20 102kw
late(current) 112 or 114kw...
Not sure of year change overs...
Correct me if this is wrong...
maddog
Post by maddog » Fri Feb 15, 2008 3:52 pm
Thanks to all of you for your input!!! Looks like I'll be putting an EJ20 Non turbo in my L Series Touring Wagon (EA82NA) - I can't wait to drive it!
I'll source a decent Front Cut and take it from there...
Singularo
Post by Singularo » Fri Feb 15, 2008 11:12 pm
SUBYDAZZ wrote:They don't care what the output is, it is only the capacity, you may put a Honda S2000 motor into a car that was an EA81/82 if your heart so desires. As long as the emissions are same or better and all the anti-pollution gear is retained and no major structural changes take place it is an "Owner Certified Modification" as Peejay says.
Anybody done the conversion/got it inspected in South Australia?
seagull
Post by seagull » Fri Feb 15, 2008 11:35 pm
I can tell you my Ej20 quad cam NA motor with a pod filter & a custome set of 50mm headers made 120hp at the wheels ( two )
Singularo
Post by Singularo » Fri Feb 15, 2008 11:45 pm
Looks like an EJ18 would be the only option in South Australia?
http://www.transport.sa.gov.au/pdfs/per ... gvm_01.pdf
Although it looks like you might be able to request an approval before starting if its not on the list.
http://www.transport.sa.gov.au/pdfs/per ... etin_3.pdf
Lots of other interesting info in that one.
Found some NSW stuff also.
