Driving home today (day off) about 3pm, car cuts out on freeway, no ignition lights, roll to a stop.
Key in the run position, no lights or gauges.
Get towed home, ignition fuse blown, replace fuse, key on, two seconds later fuse blows, lights go out.
So a resistive ground? Yes, traced to fuel bowl vent solenoid 0.8 ohm, spare I had lying around on another carb - 20 ohms,
swapped it over, hooked everything back up, on the road again.
So, for the boys still running an Hitachi carb, be aware that if this happens to you,
take a look at the back of the carb for melted wire at the solenoid.
