Ticking/knocking on ej25
madmat
Post by madmat » Sat Jan 19, 2008 5:06 pm
i think i am not happy:(
just done the head gaskets on my ej25 and she has what sounds like lifter tick on the left bank only. because i didn't have the shims to properly adjust the tappets i set them as close to spec as i could but they were a Little looser than spec. I didn't think they would make this much noise. ( even the wife commented)
The thing is the sound seems to be coming from the head gasket area rather than the rocker covers:confused:
Can i adjust the lifters in the car and do i have to pull the timing belt off to do this or is there some real neat trick? (i really want the neat trick option)
if it's not the tappets are there any other ideas? I don't think it's piston slap because it had none before the work?
Now where is that 6mm bolt i lost??? LOL
(as a Qantas pilot once described it, it sounds like a midget in the engine with a hammer)
Any help is appreciated
______________________________
my last 4wd that i built and had fun scaring subarus on fire trails:twisted:
full NSW rego. 270liters diesel. 140liters of water. airide suspension on front axle.
self contained for a week with 6 adults. Island cab was cut and narrowed 300mm to fit the chassis.
Great fun off road. Now lives in FIJI as a mobile dentists truck.
Matatak
Post by Matatak » Sun Jan 20, 2008 11:54 pm
i thought they were all Hydraulic.
sure one just hasnt bled up properly yet?
wt year is it im sure my Dads old 96 Outback EJ25 was hydraulic
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
madmat
Post by madmat » Mon Jan 21, 2008 7:13 am
the car is 97 but the motor is made up from a few different years. i say it's not hydralic because on top of the valve is only a cup and shim as far as i can tell there are no seals or any othing things indicating hydralic lifters. i could be wrong????
i have found that i'm not getting oil to the cam brgs so this could be my problem. i have oil to the head for sure as i pulled the plug at the front of the head and cranked the motor and oil came out. so i have to find out what is blocking the gallery????
FROG
Post by FROG » Mon Jan 21, 2008 7:45 am
shims on yours mat
tryin to find out if there is an easy way
madmat
Post by madmat » Mon Jan 21, 2008 7:47 am
So are you saying no Hydralic lifters???
HOw mach are the shims to buy???
FROG
Post by FROG » Mon Jan 21, 2008 7:57 am
correct about 13 dollars need to know thickness reqd to two decimal places in mm
ie 1.94 mm
madmat
Post by madmat » Mon Jan 21, 2008 7:44 pm
In seeking to resolve the noise in the motor i found this tiny oriface in the head that had gat a tiny piece of somthing in it. this was blocking the oil flow to the cam shaft brgs. I also hope it was the cause of the knocking before i put it all back together to find i still have problems.:confused:
The pictures show the location of the oil plug and the ristrictor inside. I used a paper clip to clear it. Compressed air would work better i think. after clearing it i cranked the motor till oil cam out the oil galleries.
sorry the pics are a bit crap i still have to work out how else to upload bigger files.
Missalanious 004.jpg (33.18 KiB) Viewed 2035 times
madmat
Post by madmat » Tue Jan 22, 2008 4:44 pm
after clearing out the restricter the first time it then blocked up a second time. *&^%& it all seems to be good now and i can see oil flowing on the camshaft when i remove the oil filler tube.
The main ticking noise i believe was caused by the tappets being too tight on the exhaust valves of cylinder number 2.
The power seems to have come back as well so hopfully i'm on the home stretch.
