imprez me
dibs
imprez me
Post by dibs » Thu Jan 10, 2008 8:43 pm
hi guys
what hp is a 94 impreza 16 valve and what would be a good price for one with 27000 ks with computer needs crank sensor . what box and is it an easy transplant ???
dibs
Suby Wan Kenobi
Post by Suby Wan Kenobi » Thu Jan 10, 2008 11:11 pm
92KW, Crank sensor will set you back $100 second hand, Manual will be dual range with 1.45:1 low, an easy transplant to what?
The long road ahead
dibs
Post by dibs » Fri Jan 11, 2008 1:58 pm
sory guys brumby of course
dibs
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Jan 11, 2008 2:52 pm
If its AWD it will have the dual range gearbox and its a pretty straight forward swap to a Brumby. You will need to elongate the engine mount holes further outward and make your own gearbox mount other than that you are only stripping the harness. Depending on how you do the conversion you may need to move the battery
The long road ahead
dibs
Post by dibs » Fri Jan 11, 2008 5:09 pm
thanks suby
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Jan 11, 2008 8:11 pm
If you need any more help just ask
The long road ahead
Bumpty
Post by Bumpty » Fri Jan 11, 2008 9:58 pm
I learnt about Crank shaft sensors the other day in my bros commonwhore on a four Hr trip (four Hrs from top to bottom of tas... long way for us!)
good luck with the Imprezza!
