Touring wagon gauge cluster to a DL
subalex
Post by subalex » Thu Jan 10, 2008 7:16 pm
I have just acquired a gauge cluster from a Touring Wagon that includes the tacho that my DL's dash doesn't. From what I've looked at, it should simply plug straight in and work. Are there any inconsistencies between the wiring from factory? The only difference I am after is the tacho of course and from what I can see, it looks like the loom comes pre-wired the same for all the cars, regardless of model. Both are L-series cars.
'91 Sportswagon - 3" lifted, 14" speedys, 27" Nankangs + lots of small details improved. Wouldn't mind some extra grunt from an EJ.
Post by Gannon » Thu Jan 10, 2008 7:27 pm
Unfortunately not
You will have to do a bit of wiring work as the plugs are not the same. Because the guages are in different places, so will be the wires.
Its been a while since ive done it, but if you are willing to do a bit of wiring, i can help you.
subalex
Post by subalex » Thu Jan 10, 2008 9:32 pm
That'd be great. I've got a spare dash out of another DL so I've been looking at the connectors and circuitry just these last few minutes (now the kids are in bed). I should be able to cut the sockets off the spare DL cluster and use them to replace the sockets on the Touring Wagon cluster. Shouldn't take too long actually. Are the colours consistent? Do you have some pics or circuit diagrams?
Post by Gannon » Fri Jan 11, 2008 7:31 am
I'll have a look for the diagrams
The wiring colours should be consistant, but they aren't always
you will also need to run a wire from the coil to the dash
subalex
Post by subalex » Fri Jan 11, 2008 10:42 pm
More than half of the colours aren't consistent so I'll check them all out manually with a multimeter and some advice from my father - specialises in auto gauges.
subalex
Post by subalex » Sat Jan 19, 2008 11:36 am
Ok, finally getting around to having a look at that cluster now. No quicker way to work this out than to check those circuit diagrams... Suparoo... do you have those?
Post by Gannon » Sat Jan 19, 2008 1:35 pm
Im looking for them as we speak
ChPLAT
Post by ChPLAT » Sat Jan 19, 2008 6:58 pm
Would the colour wires from a leone to a brumby instrument cluster be the same?
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
Post by Gannon » Sun Jan 20, 2008 3:17 pm
I have actually found the adaper loom i made
its missing a few wires, but simply connect the pin number to the corresponding wire colour in your car
I will explain wire colours as follows.... -main colour-stripe colour-band colour (in most cases you can ignore the band colour)
On the black connector....
Pin 1 - Unkown
Pin 7 - Unkown
Pin 8 -Red-Red-Blue and also extend to Pin 4 of White connector
Pin 9 - Extend to Pin 5 of White connector
Pin10 - Green-Blue-Red
Pin11 -White-Blue-Yellow
White connector
Pin 1 -Black-Yellow-Red
Pin 2 -Green-Red-Red
Pin 3 - I think this goes to neg side of coil
Pin 4 - From Pin 8 of Black connector
Pin 5 - From Pin 9 of Black connector (you may need another wire here too)
Pin 6 -Black-White-Red
Pin 7 - Unknown
Pin 10 - Unknown
Pin 11 - Unknown
Pin 12-Black-Black-Red
I will work out what the others (unknown ones) do too
