Ej22 Tps
Matatak
Ej22 Tps
Post by Matatak » Sun Dec 30, 2007 4:59 am
TPS = Throttle Position Sensor..
who knows how to set these up?
i thuhgt i read once u needed feeler guages to do it :???: but i cant remember
i dont think mines set right..causing alot of stupid s**t with my car atm.
who can tell me how to fix it
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
SuBaRiNo
Post by SuBaRiNo » Sun Dec 30, 2007 2:17 pm
I have set up mine a few times and obviously had to reset it when i changed my throttle body for the SC.
Yes u do need feeler gauges. I seriously think you should invest in the liberty Gregories workshop manual Matt. Most of the things u ask in here are clearly outlined in there. It will save you stacks of time.
If there is a problem with it it should spit a code. This goe for your O2 sensor too. Although i have had my O2 sensor play up with no code before.
Dave
Matatak
Post by Matatak » Sun Dec 30, 2007 2:41 pm
i dont think theres an actual 'problem' iwth it..i jsut think its not set right. causing my car to run rich, and surge and be annoying to me.
so the Gregories manual is way better than the Haynes book i kept frm wheni dad had his Outback?
Matatak
Post by Matatak » Sun Dec 30, 2007 2:57 pm
ok turns out ur right Davarino.
i just found it in the Haynes manual.
ill set it up right later and hopefully my car will run alot better (thats wt im countin on neway)
problem solvered i guess for the time being
SuBaRiNo
Post by SuBaRiNo » Sun Dec 30, 2007 3:06 pm
more likely to be o2 sensor for surging. Or problem with your fuel return. Mine used to surge BIG TIME... turned out fuel was making it's way back up my evap lines and flooding the motor. Might be worth blocking off the evap line and go for a 30 min drive just to rule it out.
Dave
Post by AlpineRaven » Sun Dec 30, 2007 4:43 pm
Surging can be known for MAP sensor that is dirty...
SuBaRiNo
Post by SuBaRiNo » Sun Dec 30, 2007 5:03 pm
Ohh yeah... that too. I always cleaned my MAF meter with some circuit board cleaner.
Dave
Matatak
Post by Matatak » Sun Dec 30, 2007 8:43 pm
the surging is only there when the throttle is partially on. at WOT it runs alright. but still rich.
makes me think the TPS is telling the motor the butterfly is opened more thna it is and so more fuel gets injected and causes surging.
i only jsut got home so in a bit ill go check out the TPS.
ive cleaned the MAF sensor before but maybe ill do it again
O2 sensor will be next coz i liek to know i got new stuff
SuBaRiNo
Post by SuBaRiNo » Sun Dec 30, 2007 11:16 pm
If it was the Throttle Position sensor not set right you would get a code for the idle switch which is built into the Throttle Position sensor. My opinion... if your not getting a TPS or Idle switch code then thats not your problem.
Try it and see how u go though.
Dave
Post by Gannon » Sun Dec 30, 2007 11:41 pm
Ive seen an explination on adjusting the TPS on an XT6.
With the engine running, slowly rotate the TPS until the engine stalls, then turn it back a touch. It was something like that anyway.
SuBaRiNo
Post by SuBaRiNo » Mon Dec 31, 2007 5:01 pm
That wont for for an EJ22 beacause it has the idle switch in it. This lets the ECU know it should be idleing. I would think the XT6 would not have this.
Dave
