Here's the write up. Please bear with me, its taken a long time to get the images on the web to have them posted here. Hope I don't ramble on.
Please don't post til I've given the all clear, there'll be a few
I'll start with how it all happened - It was one boring uni day... The AUSubaru site is a favourite of mine and I dropped in on the WA section to read the bbq thread, then posted that i'd see you all there or something. SuBaRiNo Dave posted back with "Do it! Do it!" and the ball rolled from there. Another thread was started to collect funds, a bit of a piss take that went wrong (thanks to all those who pledged - that kept the idea alive - and thanks Mike
Then my brother, nicknamed by me as "Bros" (very original i know), was asked if he'd like to come. Answer = yes and off we went.
I'm the one driving
Ruby had her head gaskets replaced to get rid of an annoying O ring oil leak and I threw in some solid lifters for some fun - that cost me a weekend to do and another to re-adjust the lifters.
Tuesday saw us off from M&D's joint via benders up to Mildura then across to renmark, pt augusta headed to ceduna - about 13 hrs on the road total.
That was about the time that i was no longer on edge about the lifters - they'd done about 1300km without a hiccup. That was also about 5 minutes before we heard a loud tapping noise - the lifters.
We made it to a parking bay, I started stripping down the motor to get to the problem lifter (found by idling the engine and using a long screw driver to find out which side it was coming from). It was about 1230am at this point in time.
Bros in his style slept on that park bench behind me... Here's one below of the engine when I called it a night:
The sleep on the ground was a good one, I woke to find bros cleaning up bits that i'd left out for him the night before - that silicone stuff is good but a pain in the arse to get off when you don't have grazing access to a fridge...
The other part of the problem was the feeling of isolation - no mobile reception... yes we were next to a major interstate highway, but do you think anyone will stop to help after Wolf Creek? Answer is no. And we needed a spark plug remover as one of the exhaust valves (the one with the dodgy lifter) had dropped one of its retainer clips - lucky the last one held otherwise we would have really been up sh!t creek without a paddle...
I used my old sleeping mat to make a sign asking anyone for a spark plug remover as without this we weren't going anywhere. Bros got impatient and went through my car looking for tools. He found a wheel nut remover for a set of mags i've got at home that use a larger nut, a nut that happens to be the same size as a spark plug! *YAY!*
To fix the valve retainer clip we had to hold the valve in place as we pushed on the valve springs and washer. This is where the spark plug remover comes into play - you remove the spark plug, shove a clean thin cloth down into the cylinder (in this case my Hungry Jacks apron that we took a thin slice off) making sure you don't loose the end of it. Once you've got a good amount of cloth in there you rotate the engine til the piston holds it in place. This allowed us to push on the spring without the valve moving. Even pushing on the spring wasn't an easy task - we used two tuna cans and a block of wood to space out from the chassis rail so we could then use a 19mm spanner as our lever arm that allowed me access to the top of the valve and washer...
We eventually got it back on, the tuna cans are now a testiment to the brut force that those little springs can give, having been dented by the spanner (we've still got them as a "trophy").
