Filler on paint?
ChPLAT
Filler on paint?
Post by ChPLAT » Fri Nov 30, 2007 1:09 pm
Put a ding in my tailgate the other night. I managed to get it rather straight with a hammer but I want to stick some filler on it. I've sanded back any flaking paint, but can I just prime the bare metal and paint work the fill over all of it?
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
Post by AndrewT » Fri Nov 30, 2007 1:49 pm
Yeah the filler will hold onto paint aswell as bare metal. It may be worth roughening the surface and drilling a few small holes to give the filler something better to grab into.
ChPLAT
Post by ChPLAT » Fri Nov 30, 2007 1:50 pm
Cheers mate
Past rides-
1989 Brumby
Current ride-
INEEDABEER
Post by INEEDABEER » Fri Nov 30, 2007 3:40 pm
Generally speaking filler should be applied to bare metal only.If the dent is only shallow you may be able to get away with it,but you may have problems when you try to feather back the edges as you will have paint between the metal and the filler.I guess it depends on how good a job you want.
]Hey I know Jack Schitte!
[/SIZE]
ChPLAT
Post by ChPLAT » Fri Nov 30, 2007 3:53 pm
Nah its like a tiny dent now I've banged it out, just want to smooth a crinkle. I just primed the bare metal spots and will put some filler over it tomorrow. Not looking for an awesome job just want it to last a couple years until I can get the whole car painted.
Past rides-
1989 Brumby
Current ride-
Bumpty
Post by Bumpty » Fri Nov 30, 2007 8:22 pm
Painted Purple?
ChPLAT
Post by ChPLAT » Fri Nov 30, 2007 9:46 pm
....why purple?
Past rides-
1989 Brumby
Current ride-
Post by AlpineRaven » Fri Nov 30, 2007 10:16 pm
You can put filler on the top, if I were ya i would make the area really rough so that the filler will stick on nicely.
Bumpty
Post by Bumpty » Fri Nov 30, 2007 10:26 pm
ChPLAT wrote:....why purple?
For the alliteration of the Ps... and lamborghini's I think look better purple then p p.. pink. And I agree with Alpine, make it rough and do it well, it probably want last till you have the paint job if ya just slap it on...
ChPLAT
Post by ChPLAT » Fri Nov 30, 2007 10:35 pm
yeah ill rough it all down first, was planning to, just to hard to rub all that area to bare metal and i have no idea how I'm gunna paint it so it'll probably look **** anyway sadly.
Ps I still don't get the purple thing :| I must be tired
Past rides-
1989 Brumby
Current ride-
riksta
Post by riksta » Fri Nov 30, 2007 11:03 pm
I agree, make shour it is VERY rough and make it bigger then the dent, you will find that it is bigger then it looks, Filler (bogg) is NOT water tight, water will and can get throw, under, around it and then you will have *RUST* under the Bogg and you dont wont that.
You mite think it is a little dent now but to fix it up right and having it looking good you will have to repair a much bigger area.
Bogg dose bond best ot bare metal so if you can have some bare metal at lest at the center of the dent at its deepest point, try not to drill holes as this allso will start RUST from both sides.
Hope this been some help to you.
