Brumby horn relay
ChPLAT
Brumby horn relay
Post by ChPLAT » Wed Nov 21, 2007 9:27 pm
Does anyone know where the relay is for the horn in an '89 Brumby? Mines gone I think. Horn still works when I run a current through it so I'm assuming the relay. Just cant find the sucker.
Past rides-
1989 Brumby
Current ride-
MY06 Liberty 2.5i Sedan
ChPLAT
Post by ChPLAT » Wed Nov 21, 2007 10:08 pm
Unit works fine when I zap it and fuse is fine. Took steering wheel cover off and that looked fine too. I just assumed it had a relay but couldn't find it or even where it connects into the car. Oh well if all else fails I'll re-wire the low one at least. High one is took annoying to get too. But i need my horn back. So many bad drivers that need it pointed out.
Past rides-
1989 Brumby
Current ride-
Subie Snax
Post by Subie Snax » Fri Dec 14, 2007 10:13 pm
it could be a bad conecting boss kit.... thats if you've changed your steering wheel.... or you could just check the original one anyway///
ChPLAT
Post by ChPLAT » Fri Dec 14, 2007 10:59 pm
No I don't have a boss on it. The wire around the wheel looks fine its just i don't know what i'm looking for under the hood.
Past rides-
1989 Brumby
Current ride-
Matatak
Post by Matatak » Fri Dec 14, 2007 11:02 pm
still havent fixed it?
theres a little bit of metal right behind the steering wheel whihc needs to contact on the wheel and stay contacted as u turn it..its kinda on a spring loaded thing (but without a spring) to hold i on. if that stops connecting it wont feed down to the horn
(on mine neway)
u probly got no idea wt im on aobut..but try looking behind ur wheel neway
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
