EA82 NA/Turbo radiator hoses ?
discopotato03
Post by discopotato03 » Tue Oct 23, 2007 5:31 pm
Hi all , getting the run around trying to find radiator hoses for my 85/86 RX Turbo sedan . Repco reckons there is mention of a turbo model but no hoses or part numbers . Auto One can supply hoses for EA82 but no mention of a turbo model .
From what I think I've seen all L series EA82 radiator hoses are the same aren't they ? Anyhow two hoses on order through Auto One but they can be returned if necessary .
Anyone know the true story , cheers Adrian .
Post by Gannon » Tue Oct 23, 2007 5:52 pm
i cant see why there would be any difference
Post by steptoe » Tue Oct 23, 2007 11:23 pm
I got the only ones I could find - non turbo. Components are the same BUT i found the bottom hose end at water pump pipe a bit funny d!ck in a sleeve coz of the bend but just screwed it tight
CH2604 was one part number, the other is probably one number higher or lower
Gremlins
Post by Gremlins » Wed Oct 24, 2007 8:15 am
Radiator hoses for N/A EA82 and turbo are the same.
discopotato03
Post by discopotato03 » Wed Oct 24, 2007 3:57 pm
Yes confirmed they are the same . Repco and Auto One to note .
Cheers A .
Post by steptoe » Wed Oct 24, 2007 10:30 pm
maybe they have turbo listings - and you pay more for them :)
Post by El_Freddo » Fri Oct 26, 2007 3:24 pm
Is there a slight difference between that of the carbie and MPFI/Turbo EA82's?
