how many revs you do at 100 kph? IN TOP
Post by steptoe » Thu Oct 18, 2007 1:50 pm
just curious to see differences of alll our combinations of cars, tyres and gearboxes - to see how many revs you are doing at 100 klicks in top gear >> edit<<< I used Roadangel EVO GPS speedo
I have no tacho hooked up to the Brumby so no idea
MV Brumby, 5 speed top 2 are overdrive i think
3.7:1 diffs
195/50-15
MY Lseries 3 speed auto 1:1 top ratio
3.45:1 front diff
175/70-13
- about 3200rpm is that normal ?? combine that with the std boost turbo no wonder it drinks petrol - exact consumption nt measured yet..........next check it is about 3350rpm at 100 kph GPS -if tacho is correct
BlackMale
Post by BlackMale » Thu Oct 18, 2007 2:28 pm
about 3200 sounds about correct.
Jack
Post by Jack » Thu Oct 18, 2007 3:07 pm
Outback, EJ25 and manual gearbox, 4.444 diffs, 215/60R16 tyres
100km/hr = 3000 rpm
1999 Outback (some mods)
1989 Brumby (more mods)
subelover
Post by subelover » Thu Oct 18, 2007 4:20 pm
3200rpm 3.7 rear diff at 100kph :)
Suba
Post by Suba » Thu Oct 18, 2007 6:49 pm
Liberty 4.444 diffs, Auto , 205/55/16 2800rpm at 100 kph ,and that speed is acurate off gps.
Mike.
Post by AndrewT » Thu Oct 18, 2007 7:43 pm
I was going to point out....most people on here probably aren't actually going 100km/h when their speedo says they are (due to 14" wheels, different tyre profiles etc).
Then I realised that doesn't really matter in this particular discussion because the original question relates to engine revs vs speedo reading in relation to gearbox ratios. Tyre size doesn't effect any of this so the actual speed the car is travelling also doesn't matter =)
I think I understand myself...
stinky
Post by stinky » Thu Oct 18, 2007 8:55 pm
I usually sit around 2800rpm @ 100km/h in the brumby. 3.9 5spd, 15" rims, not sure of tyre size.
Smokey
Post by Smokey » Thu Oct 18, 2007 9:00 pm
13" 3.7diff @ 100 is just under 4000, that's the 3psd auto!!! OMG that sux.
The 3.9diff manual @100 is approx 3000, but that's also w the nankangs on 14" rims.
PeeJay
Post by PeeJay » Thu Oct 18, 2007 9:11 pm
I think mine was 2700, L AWD Manual 3.7, 205/75/15. I know it's spot on 3000rpm at 130kmh
Post by Gannon » Thu Oct 18, 2007 10:10 pm
Thats probably your heavy foot!
I was expecting better fuel economy with my turbo motor too, at least better than the carby that preceded it.
But alas i think my love for that lump of toruqe near 3k rpm is what drinks it all up. My economy is worse than with the carby
julian
Post by julian » Thu Oct 18, 2007 10:52 pm
3.7 ratio. As Andrew T pointed out an indicated 100kmh will always be same engine revs regardless of tyre size, which puts my car at just under 3000, but if tyres are taken into account then my speedo will kiss 2700rpm at a true 100kph.
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
Post by El_Freddo » Fri Oct 19, 2007 12:44 pm
julian wrote:3.7 ratio. As Andrew T pointed out an indicated 100kmh will always be same engine revs regardless of tyre size, which puts my car at just over 3100rpm, but if tyres are taken into account then my speedo will kiss 2800rpm at a true 100kph.
So whats your tyre size?
My standard 88 L wagon with 3.7 diffs sits at about 3100 at 100km/h... or about 4000 in 4th... and about 3500 revs at 110km/h.
00outback
Post by 00outback » Sat Oct 20, 2007 9:51 pm
I'm doing 2800rpm at 100km in my Liberty which is 3.9 ratio and 2600rpm at 100km in the Outback I'm not shore on the diff ratio.
Steve
INEEDABEER
Post by INEEDABEER » Mon Oct 22, 2007 6:18 pm
My 97 outback does 2500 at 100kmh.4 SPEED AUTO 4.11 DIFFS,205/70X15 TYRES.:p
Matatak
Post by Matatak » Mon Oct 22, 2007 7:22 pm
mine was doin 2900 at 100KMH on the weekend (speedo reading not actual).
original 4 speed box with 195/65 14s
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
BRUMBERTY
Post by BRUMBERTY » Mon Oct 22, 2007 8:35 pm
3.9 diffs, 225/65/15's 100kmh = 3000rpm exactly.
Speedo perfect, GPS checked.
110 kmh = 3500 + rpmmmmmmmmm (full boost, top gear)
1989 Subaru WonderBrumby II
Post by Alex » Mon Oct 22, 2007 10:03 pm
4.111 diffs, 215/40/R17 at 100kmh just under 2500rpm. (4speed auto)
Phizinza
Post by Phizinza » Tue Oct 23, 2007 9:27 am
Brumby, FT4WD 3.7 ratio, 27x8.5R14 MT's (26.3" OD)
2750rpm in 5th at 100kph.
Post by steptoe » Tue Oct 23, 2007 11:50 pm
additional note: this baby is auto and i have seen differing revs/speed uphill and cruisng V's downhill. slippage ?
thanks for the input people.
timmo
Post by timmo » Wed Oct 24, 2007 8:40 pm
a tad over 3000rpm in the L turbo wagz and about 2400 rpm in the RS
L series wagon EA82T (RIP)
'92 Liberty RS Turbo
GU Patrol Ute
Honda XR400R
