To Prozone or not to Prozone?
Reg Brumbys
Post by Reg Brumbys » Mon Sep 24, 2007 9:37 am
:confused:
I was having a yarn to a Mechanic and he was saying that the 90 Brumby I have was built with leaded fuel in mind and not unleaded - he said that I should look at getting a "Prozone" fitted to the fuel line to get the best performance out of it.
It's meant to be a fuel conditioner -
". The fuel passes over three to seven complex alloy amalgam cores.
2. Then it passes over two or more powerful earth, sintered ceramic magnetic cores which alters the free electron structure of the fuel, polarizing the fuel hydrocarbons prior to combustion "
Most of the stuff I heard about these things has been that they aren't worth a squirt but I was wondering if anyone has actually tried one and the results of it?
http://www.prozone.com.au/default.asp?page=p5
BaronVonChickenPants
Post by BaronVonChickenPants » Mon Sep 24, 2007 9:41 am
He's got an eye on your wallet and he's not letting go.
No need for any of that, any engine with alloy heads already has hardened valve seats suitable for unleaded fuel, the subaru's have been running on unleaded in japan from the mid 60's so I'm told.
Jordan.
Suba
Post by Suba » Mon Sep 24, 2007 10:57 am
In a word or two , don't be fooled into these things, none of them are really worth it and as BVCP said the Subi engines have been running un-leaded fuel from the late sixtys.
Mike.
dfoyl
Post by dfoyl » Mon Sep 24, 2007 12:44 pm
The EA81 was designed for higher octane fuel than regular unleaded 91, but the leaded/unleaded difference isn't relevant. Most engines since the early 70s have hardened valve seats (the US big three introduced them in 1971-73). You'll get better performance out of 95 octane fuel with timing set accordingly.
The prozone model reminds me of Brocky's energy polarisor, and we all know how successful that was :rolleyes:
Dean.
Reg Brumbys
Post by Reg Brumbys » Mon Sep 24, 2007 5:44 pm
Thanks Lads - Think I'll spend the money on an Electronic Distributor or a MSD Blaster 2
thanks
Reggae.
subanator
Post by subanator » Mon Sep 24, 2007 5:45 pm
One performance mod recommended for any EA81 - Weber carby, runs more advance and get more power and economy can improve if driven sensibly. Also yours would have electronic dizzy but others on the board have gone with a high output coil like the MSD Blaster. Save ya money for some mods that DO work.
Reg Brumbys
Post by Reg Brumbys » Mon Sep 24, 2007 5:56 pm
Ta - yeah I'm a bit of a green horn ( I just replaced the Ignotor Module - should have been obvious.
So the Weber Carby is a go eh - and mabey the blaster?
Subyroo
Post by Subyroo » Tue Sep 25, 2007 5:14 pm
subanator wrote:Save ya money for some mods that DO work.
Yeah!, I agree with Subanator too.
Go and buy a Hiclone instead, that will put a Cyclone under your bonnet and give you more power and more mileage ie 15-20% fuel savings. :twisted: :twisted: :twisted: :twisted:
P.S.
Please forward all monies for Consultancy Fee to............ ;) ;) :-D
Peter
daveosubi
Post by daveosubi » Tue Sep 25, 2007 5:25 pm
Im wondering what the guys credentials are calling himself a mechanic, pseudoscience isn't a science.
Dont forget the oxygen tablets you put in your tank, i see them being sold at servo's around me.
Ben
Post by Ben » Tue Sep 25, 2007 7:40 pm
Electric Superchargers are on ebay and easily add a ton of powa!!
Please watch before posting!
Wraith
Post by Wraith » Thu Sep 27, 2007 1:09 pm
what about the piston return springs, and cross drilled brake lines.
amazing upgrades you can do.
why not install a muffler bearing while you are at it.
and dont forget to fill the fuel tank with unobtainium. - works a treat.
Destroy waves, NOT beaches.
1990 L Sportswagon (Mine)
1988 L Touringwagon (Hers)
1998 Liberty GX Wagon (Ours)
1987 L Touringwagon (SOLD!!)
1986 L Jap Import Turbo wagon (SOLD TO TIMMO!!)
1986 L RX Turbo wreck (SOLD TO TIMMO!!!)
