overheating EA82 radiator stuffed i think
sounds like i have a similar prob to another overheating EA82,
i thought my temp was a bit high due to a constant leak of fluid so i decided to put some of that 'Stop leak' stuff in the radiator.
WELL it stopped the leak, and the flow of coolant throughout the radiator.
NOW after about 5min drivin my temp gauge sits just below the red line, however ...if i flatten the pedal, the temp seems to drop, temporarily, until i set to cruise again.
off to exmouth on satdy or sundy and need this problem fixed!!!!!!
what r my options? cud this be the head gasket? wud a new or recon'd radiator be the better choice for money value.
PS. got the radius rod fixed and exhaust system put in, tires on tomorra. was all good till this problem.
New Ride: 1990 L touring Wagon, 2"Lift, Rear Wheel Carrier, Cargo Barrier, Roof Bucket, Replacment Bullbar, Spotties, 27" BFGs
EJ20t sti
01 Sti running gear.
Want :Dual range forester box to suit
Rip:93 L 2 1/4" exhaust, 14" sunraysias, cargo barrier, 32/36weber, king springs, KYB's, 3" lift , 27" rubba. 15" superlites.
EJ20t sti
leak was bottom right corner.
i thought a lack of circ'n but why does it cool when i floor it?
EJ20t sti
EJ20t sti
tank, previous junk clogged it, then had a service and they flushed out junk to expose leak. say i need a new raqd, thermostat and pump, what damage am i lookin at?
EJ20t sti
EJ20t sti
hmmm depedns how much u got to spend
rad (new) maybe like 350 to 400 rough price (aint sure) pump culd be like 100 to 150 (rough) thermostat like 30 i guess coolant depends where u get it etc add liek antoher 50 roughly for distilled water and a bottle of premix stuff.
for some1 to do it all maybe like add 200 lol
so with my very rough prices all up adds up to around $830 lol
u culd probly get away with doin just like a new rad or something but i dont liek chancing crap liek that to much to go wrong later
Wagon is no longer....
Distilled water is completely necessary90brumby wrote:ur prices might b a tad high there thermostats retail at like 18 buks coolant 20 buks distiladed water not recessary i think i have a rad here somewhere if u need it
u cant use tap water in cooling system completely screws em over and ull end up with more problems than u started with. (ofcourse not a prolbem over east apparently they dont haev the crap in the water we do)
Prices are high coz i liek doin things thhat way lol..better to overestimate than underestimate i say
just thinking of this
who doen ur radiator if u got it cleaned etc then whoever did it usually shuld pressure test it to find any leaks and if they do they shuld of fixed it. Lseries rads are metal aretn they (tanks) if so easily get it welded or the likes to stop it
but puttin Stop Leak wont affect the cooling system only make it better if its leaking. (only use em at work for headgaskets dont usually for rad leaks)
if you can find a little tube of Silver Seal (blue cardboard tube about 20mm dia 80mm long) at say Autopro. It has little powdered flakes of stuff to seal radiator leaks. Have used it many times for emergency situations to buy time. My brother still has it in from a year ago ! STICK ONE in the glovebox for next rad leak.
