ej22 engine mods
- tassyraider
ej22 engine mods
hi all
just about to build up a ej 22 block,ej18 heads,18 injection gear
has any one done this,if so what pros/cons about this conversion
the reason for 18 injection as my wireing is done
cheerz mick
cheerz mick
current ej18 awd targa brumby
95 impreza awd sportz wagon
Wouldn't using ej18 heads be a down grade?
Dave
Dave
- tassyraider
Might have a smaller chamber would probabily = higher compression depending on what the cam timing is doing. The valves may be smaller too - you'd want to check this out.SuBaRiNo wrote:Wouldn't using ej18 heads be a down grade?
Dave
On old holdens a trick to get them moving with the old sixes was to get a head from an engine size below (or two below) what you have - these have smaller chambers and help easily increase compression, with a good cam etc you'd have a sweet performance engine...
I reckon there'll be problems with the computer and leaning out, it may adjust itself enough to get by but could be outside the fuel delivery range. Larger injectors may help.
My 2c
