my ea82t cam setting
dj fbi
Post by dj fbi » Sat Aug 25, 2007 8:53 pm
I finally have done more upgrades to my love (if you havent seen any photos she's a 1989 L series touring wagon)just put in a td04 turbo 3 inch stainless wrx zorst and new heads but not sure if cams are lined up right. With the three cam lines on the flyweel should the drivers side (australia) cam hole be shraight up at the notch and the other side (a/c side) be straight down i can not rember :confused:.
Post by steptoe » Sun Aug 26, 2007 10:33 am
i have trouble rememberng too , one belt is set then a rev turned to marks again and set the outer belt timing. There is suposed to be a manual in pdf form in here that should be helpful if you can find it or some1 fit a link in here for you.
Post by El_Freddo » Mon Aug 27, 2007 5:51 pm
go to the tech manual - the thread named something like "PDF manuals?", its down the bottom of that thread...
Happy hunting.
