the epoxy resin came in a 250ml tin *polyester resin LSE
the hardener is in a 10ml bottle * polyester catalyst 23mm dia x 26mm high of fluid
mix ratio is 10ml to the litre. I want to do 50ml resin at a time.
25% of this 10ml bottle of hardener will do the full tin, so I need to measure out 5% of this 10ml bottle , half a millilitre.
PICTURE THIS. with water one millilitre weighs one gram and volume is one centimetre cube, bit like air. so a ml = a cc ? right ? 1000cc = 1 litre = 1000ml , right ?
I am wondering how many drops of hardener to my 50mls resin.
IT GETS WORSE
In front of me is a 50ml measure out of my Gatorade powder keg. Same volume as a medicine measure cup. It measures 46mm dia by 26mm high. I CANNOT IMAGINE THAT IT WILL CONTAIN 50 WHITE CUISENAIRE RODS (1cm x 1cm x 1cm)
any engineers, maths bods, school teachers able to clear up my mind fog...please?
I can however see that one 50ml measure will fit in the 250ml tin 5 times and that 5 times the 10ml will go in the 50ml measure. It is the 50ml = 50 cubic centimeters I cannot visualise or fathom. Got the scale wrong ? Out comes the plasticine
26mm high divide by 4 for full tin = 6.5mml high, then divide that 6.5mm fluid high in bottle by 5. Every 1.3mm in hieght of fluid (catalyst per 50ml resin. SORTED !!
thanks !
