FWD Rear Disc Brakes to fit MY/L...?
L-Raiser
Post by L-Raiser » Wed Aug 08, 2007 11:03 am
Does anyone know if Vortex Front Wheel Drive REAR DISC BRAKES can be modified to fit an MY or L.....?????
Because I have a set out of a Vortex FWD that a guy on the other side of OZ wants to buy off me to fit to his Brumby.... He and I are of the belief that they can be fairly easilly modded to suit 4WD application, by creating a hole in the hub for the rear drive shafts to fit through.
Has anyone done this mod...??? or know of anyone who has...?
Coz before I prep and ship these I want to make sure this guy can use them.
L-Raiser
:rolleyes:
Post by AndrewT » Wed Aug 08, 2007 11:48 am
I have no idea if this would work.....surely somebody has tried it....
Try taking the brakes and backing plate off the 2wd hub and put them onto a drum brake 4x4 rear end (in place of the drum brakes).
Post by AndrewT » Wed Aug 08, 2007 11:50 am
hm on second thought this most likely will not work, there won't be any splines on the 2wd hub to match up to the 4x4 axel...
SuBaRiNo
Post by SuBaRiNo » Wed Aug 08, 2007 11:58 am
I was always told it wasn't possible.. i could be wrong.
Dave
dfoyl
Post by dfoyl » Wed Aug 08, 2007 12:27 pm
They will fit a 2wd MY or L, but not a 4wd so no good for a Brumby.
Dean.
Fury
Post by Fury » Wed Aug 08, 2007 1:06 pm
It definately, posatively WON'T work.
I have had both and directly compared them.
Chris :cool:
'88 Vortex AWD turbo with "go hard" attitude -
WRX EJ20G and box , TD05 Turbo and 4.111 running gear.
5 Stud conversion (Crossbred Performance) Multi pot GT Legacy brakes and 17" rims
Plenty of plans... the plans are getting done slowly;).... getting there - NOT! ;)
Matatak
Post by Matatak » Wed Aug 08, 2007 8:04 pm
lol nope cant see it working either
show us a pic of the actual disc and ill show u a pic of the ones i got and see hwo different they are
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
L-Raiser
Post by L-Raiser » Thu Aug 09, 2007 10:38 am
Matatak wrote:lol nope cant see it working either
Thanks guys, for your input.... most valuable....
Matatak, there is a link to the PIC of these Rear Disc Brakes at the bottom of my first message...
Regards,
L-Raiser :)
Phizinza
Post by Phizinza » Thu Aug 09, 2007 11:10 am
I was told by a guy on ebay that it was possible and he done it.. but he was trying to sell a set of FWD rear discs so maybe he was just trying it on.....
Matatak
Post by Matatak » Thu Aug 09, 2007 9:06 pm
L-Raiser wrote:Thanks guys, for your input.... most valuable....
Regards,
L-Raiser :)
lol yer id seen that one
that aint a pic of the actual disc its a pic of the backing plates lol
the actual disc id expect is way different to wt is needed id think
L-Raiser
.....is this better?
Post by L-Raiser » Tue Aug 14, 2007 4:23 pm
Matatak wrote:lol yer id seen that one
....Well....I figured that the side that counted was in fact the BACK of the brake to show what could or could not be done 'driveshaft-wise'....
Here is a pic of the front for ya.... :)
L-Raiser
Matatak
Post by Matatak » Tue Aug 14, 2007 7:31 pm
lol took ya tme
unfortunantly for u mine are on the car so i cant be bothered pulling a wheel off to take a photo but ill tkae one with it on if ur interested
im guessing theres no splines under that hubcap as the bearings cant run to well on splines
Ben
Post by Ben » Tue Aug 14, 2007 8:16 pm
Chris is correct,
Not a chance this can work. The discs fit, the calipers fit, the backing plate fits. It is the hub that is different, the 2wd rear hub is just a bearing carrier, like on the front of a commondore. The 4wd rears are a splined hub, just like the front of an L series, only a different spline pattern.
Please watch before posting!
Fury
Post by Fury » Tue Aug 14, 2007 8:18 pm
As I mentioned in my previous post, they are not the same - there are no splines, there is a stub axel on the swing arm.
It is a different size, there is really no comparison from a driven hub (ie rear 4wd hub) , to a free wheeling hub . even the backing plates slightly are different.
Close but no cigar...
Chris :cool:
Matatak
Post by Matatak » Tue Aug 14, 2007 8:23 pm
backing plates cant eb hard to modify or even amke new ones
all some1 wuld need wuld be a new pair of discs then with the splined centre
thats to say the calipers are interchangable with both
Post by AndrewT » Tue Aug 14, 2007 8:34 pm
Nah, the 4x4 discs don't have the spline in them, they bolt to the 4x4 hub which is what has the splines in it.
Otherwise it would be as simple as calling up your local DBA reseller and getting new discs.
Theres no way to do it without remanufacturing the whole thing really.
Matatak
Post by Matatak » Tue Aug 14, 2007 8:37 pm
ermm i thught they did when i was putting mine on
must be dreaming or something
owell
Post by AndrewT » Tue Aug 14, 2007 8:43 pm
I could be getting mixed up with Lib stuff.
Okay....I'm intrigued propperly now - lets figure it out once and for all. I'm gonna go over to where my RX is and bust out some photos in the next couple of hours and post them up. Hold me to it!
Fury
Post by Fury » Tue Aug 14, 2007 9:02 pm
If it were easy, everyone would be doing it.
It is also why they are as rare as rocking horse ****... and expensive to buy second hand.
I have a set of 2wd rears sitting here, all rusted up now... they were listed for sale here years ago.
I should get around to tossng them...
Chris :cool:
Post by AndrewT » Tue Aug 14, 2007 11:42 pm
Matatak wrote:ermm i thught they did when i was putting mine on
owell
dreaming I think,
Splines are in the hub, not the disc.
`86 RX turbo 4x4 disc brake rear end pics from just then;
http://members.iinet.net.au/~carine3/IMAGE_063.jpg
http://members.iinet.net.au/~carine3/IMAGE_064.jpg
http://members.iinet.net.au/~carine3/IMAGE_065.jpg
http://members.iinet.net.au/~carine3/IMAGE_066.jpg
http://members.iinet.net.au/~carine3/IMAGE_067.jpg
Could get custom hubs made up....but ask Bratgebah how expensive this is =)
