how do selector shaft seal on L auto ?
Post by steptoe » Wed Jul 25, 2007 7:28 pm
I have a leak at the selector shaft seal on the L but stuffed if I can see how you fit a new o ring and dust seal on a shaft that does not have a nut to remove and the linkages to follow.
Who knows ? 4WD and fwd auto should be the same
Suby Wan Kenobi
Post by Suby Wan Kenobi » Wed Jul 25, 2007 9:41 pm
If the seal is stuffed the bushing will be too
The long road ahead
Post by steptoe » Fri Jul 27, 2007 12:28 am
starting sound a good reason to rip it out and chuck in its 3.9 ratio 5 speed !! NOT looking forward to the pedal box swap.
Post by El_Freddo » Fri Jul 27, 2007 3:04 pm
jono wrote:starting sound a good reason to rip it out and chuck in its 3.9 ratio 5 speed !! NOT looking forward to the pedal box swap.
Just rip the dash board out, will take half a day to work it out if you haven't done it before, but it will give you maximum access to the pedal cluster...
Suby Wan Kenobi
Post by Suby Wan Kenobi » Fri Jul 27, 2007 7:01 pm
You can swap out the pedal box by simply removing the steering column, you dont have to remove the dash.
The long road ahead
Post by steptoe » Sat Jul 28, 2007 11:11 am
It is gonna have to happen eventually but in the meantime, has anyone got the know on these seals, even if the bushing stands to be stuffed a temporary fix for rego inspection and pass s needed.
