Figuring things are out by a tooth (lift dizzy out, wind back - clockwise- one tooth) so and will need to rectify to drive run right
BUT can a low compression motor such as these EA82T even run at 60 degrees Before Top Dead Centre ? - at idle.It would seem they can idle and rev up no load. Just never come across this before, always owned High Comp motors, so brain has troubling believing what it is seeing. Also allowing for the fact 1200rpm is faster than the 750 rpm idle it should have and that 1200 would have SOME advance on the 20 for idle .
with acc cable too tight it was idling at 1800 then what sounds like pinging activating knock sensor to kill engine till it touched 1200rpm then back up to 1800rpm and back, just cycling. next start when warm...needs more fiddling
BUT ITS GOING
Yee haa....
